Wiring A Switch; Tips, Tricks, Things To Watch Out For? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2010, 04:36 PM   #1
Wiring a switch; tips, tricks, things to watch out for?
Post deleted
user71057 is offline   Reply With Quote
Old 01-20-2010, 05:18 PM   #2
Electrician
Rewards Points: 910
Originally Posted by jbengal View Post
The live and neutral wires in the junction box were each made of a single, rather thick, copper strand (maybe a sixteenth of an inch in diameter) with old rubber insulation. I'd say the building is 110 yrs old
This sounds like knob and tube, if so i would run away from the job. If someone called me to do a sidejob that involved knob and tube I would say no.
My questions:
1) The dimmer switch my friend already bought cost about $8; will it be able to handle the voltage/amperage running through it?
You should be fine, dimmers are rated in watts, you probably have a 600W dimmer so you should be fine
2) Is there a graceful way to join old single strand copper wire to modern wires (a bundle of smaller wires wrapped in housing). My thought now is to carefully bend the copper wire into a loop and then wrap the dimmer switch's wires around the copper loop.
Put the wire from the dimmer next to the copper wire(i extend the stranded wire an 1/8" further then the solid) then twist the marrete on. Give a tug on the stranded wire to make sure it is in the marrete tight.
3) Is there a special wire nut (larger diameter) I should use to accommodate the thick copper wire, especially once it's folded into a loop?
No need for a loop, see question 2.
4) The seemingly age-old question: should I then wrap e-tape from the nut to the copper wire's housing?
Not needed, as long as the marrete is on right the wire is going nowhere.
fffff
darren is offline   Reply With Quote
Old 01-21-2010, 08:47 AM   #3
Licensed electrician
Rewards Points: 3,662
Read the instructions that came with the dimmer. You may find a warning about using the dimmer with older low temperature rating wiring.
Old 01-21-2010, 09:49 AM   #4
Consider, also, the implications on working on an apartment). Does your friend own this appartment or rent? Do you have permission of the owner? Also, the legal implications....you are potentially putting at risk the other tennents, not just your friend. Is it worth it?
oberkc is offline   Reply With Quote
Old 01-21-2010, 11:26 AM   #5
Household Handyman
Rewards Points: 1,412
Listen to "oberkc". This could get to be a legal issue for you!
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Wiring Double Switch fan/light mjbcable Electrical 5 10-18-2009 06:56 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a single switch with 3 way switch using old wiring chriscam75 Electrical 3 02-17-2009 08:15 PM
