Wiring A Sub Panel Using 10/2 Feeder - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-06-2010, 11:22 AM   #16
J.V.,
I am thinking the single circuit is my best option. Will I still need to install the grounding system? Where will the GFCI outlet be in the circuit path, before or after the light switch used as a disconnect?
Scuba_Dave,
Thanks for the link to the 2008 NEC! It seems like it is impossible to find free links to this type of information which should be more readily accessible. I did find a link that showed Virginia as still operating under the 2005 NEC, is there a location to find a copy of that for free? The reason I ask is because a7ecorsair had a reference to it saying a 3 wire feed was allowed.
Willing2learn is offline   Reply With Quote
Old 06-07-2010, 09:33 AM   #17
I=E/R
a7ecorsair's Avatar
Hi,
You don't have three wires for a feed so don't worry about it and it may have changed in the 2008 NEC anyway. Three wires would be a red, black, and white. The bare ground doesn't count.
A switch for disconnect will be your first device in the shed. It will not control any other device - it will be strictly a disconnect for the entire shed.
a7ecorsair is offline   Reply With Quote
Old 06-07-2010, 10:26 AM   #18
Rewards Points: 308
Originally Posted by Willing2learn View Post
J.V.,
No need for the ground rod (system). This is a simple branch circuit. Just use a 20 amp breaker unless you plan to use #10 wire for everything, inside and outside.
Bring the circuit to the switch first, then feed the rest.
You can use a GFCI receptacle or breaker. If you use a receptacle, just put it first in the line of receptacles. No GFCI needed for lights.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Wiring from panel Rick N. Electrical 6 07-10-2013 04:25 PM
Sub panel wiring & grounding kwcamaro Electrical 1 03-06-2010 07:58 AM
Sub panel feeder wire rovers1973 Electrical 4 03-03-2010 10:02 PM
Sub panel wiring question mntnvew Electrical 13 03-02-2009 11:28 AM
