Wiring Stapled To Back Of Knee Wall Studs? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-08-2017, 05:21 PM   #1
Rewards Points: 4
Wiring stapled to back of knee wall studs?
I'm working on remodeling a 3rd floor/attic (with permanent stair access) in an older home. As I'm running electric wiring for outlets much of the length of the runs falls behind attic knee walls in the 4 corners of the space.
I'm wondering if it is permissible to run the wires on the back side of the knee wall studs, secured with staples, rather than drilling through the studs. I haven't been able to find any discussion online as to whether or not this violates any codes. It wouldn't be a huge deal to drill, but I'd rather not if it's clearly permissible to run behind studs.
The space behind the knee walls will be unconditioned space with service access only through 20"x30" access panel doors.
House is in Kansas City, KS.
mbgoss is offline   Reply With Quote
Old 08-08-2017, 05:46 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,118
Re: Wiring stapled to back of knee wall studs?
If you can run them behind the studs in a basement finish up, I am not sure why they would take issue with this.
That said, it is easiest to insulated knee walls with rigid foam so that might be easier and safer if the wire is through the studs.
The Following User Says Thank You to Windows on Wash For This Useful Post:
mbgoss (08-08-2017)
Old 08-08-2017, 05:47 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 4,638
The main thing you need to do is make sure all the cabling is protected. You can staple cables on framing members in areas that are not prone to traffic. At your access panel, make sure it is up and out of the way of your movement.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
mbgoss (08-08-2017)
Old 08-08-2017, 08:47 PM   #4
Rewards Points: 4
Thanks, Windows. I'm glad you brought up insulating the knee walls as that is the next topic I was going to ask about... I've read recommendations for insulating knee walls with rigid foam board, faced fiberglass batts, and combinations of the two, but I'm concerned that using both would create a double vapor barrier -- Kansas City gets pretty cold in the winter --... for that matter, would using rigid foam behind studs and painted sheetrock on outside of studs create a double vapor barrier???
I don't want to over complicate insulating them, but have heard multiple different methods recommended. Perhaps this is better in a separate thread under insulation...
Old 08-09-2017, 05:08 AM   #5
Naildriver
chandler48's Avatar
You can use Roxul with or without the foam, depending on the depth of your studs. It needs no vapor barrier, is water proof, vermin proof, fire proof and mold proof. In addition at 3 1/2" it gives an R value of 15, where fiberglas is only R13.
Larry......
mbgoss (08-09-2017)
Old 08-09-2017, 09:11 AM   #6
Climate Zone 4.
https://energycode.pnl.gov/EnergyCod...state=Missouri
You don't require any vapor barrier and as long as you don't use a faced insulation on the interior wall or wall paper, you can put foam to the outside without any issues.
https://buildingscience.com/document...vapor-barriers
http://www.greenbuildingadvisor.com/...vapor-barriers
mbgoss (08-09-2017)
Tags
attic , knee wall , wiring
Wiring through narrow wall spaces giansean Electrical 3 02-15-2016 06:39 PM
Insulate knee wall in Cape Cod chimera451 Insulation 6 06-08-2013 09:48 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 07:54 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
