Wiring Rolair Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 03:00 PM   #1
wiring rolair compressor
i recently purchased a rolair compressor its a 30 gl, single phase, 3hp stationay vertical compressor.I plan on having it conected next to a 100 amp subpanel in my garage.problem is im not sure wat gauge wire and breaker i need.. im no eletrician but ive wired things to my breaker box bfore so if its not to complicated id like to try myself. v3130k18 is the model #.. any help is greatly appreciated!!
wtf. is offline   Reply With Quote
Old 03-16-2010, 03:07 PM   #2
Master Electrician
Rewards Points: 5,084
What are the nameplate voltages and amperages?
brric is online now   Reply With Quote
Old 03-16-2010, 10:08 PM   #3
Idiot Emeritus
Rewards Points: 80
If the motor on this compressor is an actual 3HP (on a Rolaire, it likely is), then the following would apply;
For 115 volts, the minimum wire size would be #8 (if it's NM cable, it'd need to be #6), and the maximum breaker would be 80 amp.
For 230 volts, the minimum wire size would be #12, and the maximum breaker would be 40 amp.
Rob
micromind is offline   Reply With Quote
Old 03-17-2010, 06:00 AM   #4
Master Electrician
A single phase 3 HP motor will draw 17 amps @ 230 volts. # 12 on a 2 pole breaker will probably suffice but I would recommend # 10 on a 30 amp breaker.
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 12:46 PM
Need advice on 240 wiring for air compressor AJCady Electrical 2 10-20-2009 02:29 PM
Air compressor wiring help integlikewhoa Electrical 3 01-18-2009 11:42 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Replacing Wiring From Outside Fuse Box To Central Ac Compressor bobo Electrical 8 03-02-2007 09:23 PM
