Wiring On Pump To Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2019, 10:34 AM   #1
Rewards Points: 294
Wiring on pump to outlet
I see many newer sump pumps like blue one in pic have a single 25ft cord an the float switch wiring is short ,connected there in pump.
Is there any reason i cant lengthen -Both-my cords on my pump to 25ft though i have the pump switch wiring, that goes beside main wiring into outlet between motor plug an recepticle,on my pump,?
Or does the rating an build on specs of motor-in pic- on mine deem shorter wire only?
This would really help eliminate installing a outlet out in the weather if i can run plug ends to the direct dry outlet thats 15 -18 ft away.
Thanks.
hidden 1 is offline   Reply With Quote
Old 02-24-2019, 10:43 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,680
Re: Wiring on pump to outlet
I have to ask why do you need to extend both?
Just extend the power cord. Once you start modifying it, you probably won't get it as waterproof as the factory.
Old 02-24-2019, 10:45 AM   #3
Rewards Points: 294
Because its 18ft from the outlet an the cords[12ft] been cut in past an respliced..2 cords - piggyback method - interupter in float plug.
If i can do it i wont need to run power outside to it.
Blue one has 1 long 25ft cord to motor an short wire directly inside to float .[not 2nd plug in as mine has]
Old 02-24-2019, 11:41 AM   #4
Rewards Points: 294
Here is some of the specs .
That has 2 - 9 ft cords.not 12
Wiring on pump to outlet-20190224_112904.jpg   Wiring on pump to outlet-80745-515wx515h.jpeg.jpg
Old 02-24-2019, 12:29 PM   #5
Rewards Points: 1,306
I guess you can do it but you are adding additional lower gauge wire (typically 16 gauge or less for the pump and float switch) so if you go too long you'll have voltage drop issues.
Further what do you mean by "splice". If you mean twisting wires together and wrapping the whole thing with electrical tape, no way. That is not a legitimate splice. Similarly wire nuts are not allowed unless they are contained in a junction box. So now you are into a specialty waterproof splice kit which are available but somewhat rare.
Since this pump sounds like it is outdoors then you have the issue of GFCI tripping if your splice isn't waterproof and moisture gets in it. You are required to power this pump from a GFCI protected source.
If it were me I'd locate a weather proof GFCI outlet near enough to the pump that I could use the factory molded cords unmodified. I'd spend a bit for for a GFCI that has a audible tone when it trips so I can be alterted if that occurs (and my pump is down).
https://www.amazon.com/Leviton-A7599.../dp/B00M1VL582
https://www.amazon.com/s?k=TayMac+MM...ref=nb_sb_noss
curiousB is offline   Reply With Quote
Old 02-24-2019, 01:36 PM   #6
Rewards Points: 294
Yes ty ,i do like those audible alarms ...
Its already protected by the garage first run gfci on 20 amp 12/2..An i can up the wire size if needed for 10 more feet.. .
Im hoping maybe i can run new 12/2 or 10/2 wire with plug ends ,piggy back still, to it directly in to pump,so i can do away with building a moisture stricken outside rated outlet to it.
First pump pic ,one built with 20ft cord looks similar on amp,etc but of coarse it doesnt have its 2nd cord going to outlet as mine does.
Simple Extend an Outlet Wiring Question Curmudgeon10 Electrical 15 03-05-2015 01:21 PM
Outlet wiring; hidden ground wires Cahill_Main Electrical 4 11-26-2012 06:32 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Wiring a geothermal pump gfmonk Electrical 5 11-14-2009 02:30 PM
Well pump wiring, the correct guage? lennyjay Electrical 3 08-18-2009 12:53 PM
