Wiring Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2010, 05:00 PM   #1
Wiring Problem
I have an outlet in my living room and a light in my garage that have stopped working. Upon further investigation with a multimeter I found that somehow both the black and the white wires are now hot in this outlet. Here are the AC voltages I measured:
white to black: 2.5 V
black to ground: 124.3 V
white to ground 121.9 V
There are other lights and outlets on this breaker that still work and I have not done any electrical work that would have caused this outlet and light to stop working so I am confused about what is going on. Anyone have any ideas?
matt8200 is offline   Reply With Quote
Old 09-10-2010, 05:04 PM   #2
It sounds like you have a break or loose connection in the neutral run.
hayewe farm is offline   Reply With Quote
Old 09-10-2010, 05:15 PM   #3
yeah I just realized that was probably the problem, thanks
Old 09-11-2010, 08:22 AM   #4
Don't know if this is your issue but I had a GFCI outlet go bad on me with the result that white became hot everywhere downstream. Took me a while to track down the cause. I kept measuring black to ground and getting 120. Couldn't figure our why nothing worked until I measure white to ground and also got 120. Replacing the GFCI solved the problem.
SleepyDog is offline   Reply With Quote
Electrical wiring exposed....problem or not?? pipsal Electrical 4 03-22-2010 11:49 AM
AC wiring Problem SLEDGEHAMMER84 HVAC 12 01-22-2010 12:13 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Home wiring problem CAD Electrical 8 10-17-2009 02:26 PM
Outdoor AC on whenever heat is on - wiring problem? SammyLi HVAC 3 10-12-2008 12:29 PM
