Wiring Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 06:59 PM   #1
wiring outlet
have a well which is disconnected,which also had own wire from breaker box to motor for pump,motor is rated for 7.4 amps can not read anything else off plate,want to know can i use this wire to run a outside outlet,do believe it is 110,but not sure house is old
golf322 is offline   Reply With Quote
Old 12-09-2010, 07:25 PM   #2
Rewards Points: 1,192
Most well pumps I ever put in are 240 volt.
bobelectric is offline   Reply With Quote
Old 12-09-2010, 10:35 PM   #3
WDR
wire
If you know what breaker/ fuse it goes to youcould find out if it is 240. If it goes to two fuses or two breakers with the handles connected it would most likely be 240 volt if only one breker or fuse it is most likely 120 volt. You could also test it with a volt meeter.
WDR is offline   Reply With Quote
moving electrical outlet using aluminum wiring sjenkinz Electrical 3 12-05-2010 03:32 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
wiring in a light fixture to an existing outlet tjc460 Electrical 8 05-26-2008 10:32 AM
Outlet Wiring williamp Electrical 5 06-08-2007 10:39 AM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 09:10 PM
