Wiring In New Cooktop - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 06:09 AM   #16
A "Handy Husband"
rjniles's Avatar
Rewards Points: 700
If the specs say 120/240 or 120/208, then he needs a neutral (white wire). That is why I said in my post "(if you are stating the specs correctly)".
Many standalone cook-tops are pure 240 but if the listing is 120/240 he needs a 3 wire + ground cable and the neutral must be connected.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 10-30-2010, 01:31 PM   #17
Electrical Contractor
kbsparky's Avatar
In post number 7 in this thread, the OP stated that there was not any white or neutral conductor present:
Originally Posted by yamaman View Post
Thanks guys ok my stove only has a 3 wire coming off it red black green the two hots and ground ....
One could install a 4-wire feeder for this appliance, but would end up not using the neutral conductor ....
Hey yamaman! Can you take a photo of the end of the flex tail on this appliance and post it here?
-KB
Old 10-30-2010, 03:19 PM   #18
Hey guys snapped a pic of the wires on thr stove end of things and took a pic of the rating label too.
yamaman is offline   Reply With Quote
Old 10-30-2010, 03:35 PM   #19
A "Handy Husband"
rjniles's Avatar
Rewards Points: 700
That picture and the spec. plate mystify me. It says that the appliance is 120/240 but there is no neutral wire. I can not believe that a manufacturer would use the green ground for a neutral. Is this a new appliance?
Old 10-30-2010, 04:01 PM   #20
yep brand new electrolux full induction cooktop.
Old 10-30-2010, 04:11 PM   #21
Civil Engineer
Rewards Points: 5,246
The label does not state that the controls run on 120, the label simply states the number of kilowatts the unit is expected to draw for both 120-240 volt services and 120-208 volt services. I know it looks like it appears to be saying that the unit uses 120 volts, but it doesn't state that. Given that there is no neutral on the pigtail, it seems highly unlikely that the ground would be intended to double as a neutral, as this is not code compliant. I am assuming that somewhere in the manual there is a full discussion about the manufacturer's intended electrical connections. At least my cooktop came complete with a diagram and specs for the wiring.
Old 10-30-2010, 04:11 PM   #22
Rewards Points: 330
what does the tag say on the red wire?is it just a ul sticker?
oleguy74 is offline   Reply With Quote
Old 10-30-2010, 04:13 PM   #23
yes there is a diagram for wiring to both 3 wire from box and 4 wire, The 3 wire simply connect and go and the 4 wire it just caps the white wire off from box.
Old 11-06-2010, 05:32 PM   #24
just to let you guys know got the cooktop all wired in and working properly brought out an electrition and all is good used 6-3 wire with a 40amp brought it into a junction under the stove and wired in the whip there. Thanks for everything guys
Cooktop and Stand Alone Oven Wiring Replacing Existing Single Range/Stove Combination ffauth Electrical 3 08-23-2010 09:03 PM
Cooktop wiring upgrade Booron Electrical 7 12-08-2009 01:43 PM
Cooktop wiring debubba Electrical 3 11-20-2009 07:58 PM
Wiring Cooktop and Under Counter Oven Preach_2 Electrical 18 03-19-2009 04:30 PM
Wiring a 240v Delonghi cooktop cape45 Electrical 12 11-08-2007 02:38 PM
