Wiring In New Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2015, 07:03 PM   #1
Rewards Points: 463
Wiring in new breaker
I am running a new line for our dishwasher. I have the wires ran. Who ever wired the house was thinking ahead, and ran extra conduit to run wire in the future.
Ive done this before but it was a while ago. I know the hot wire goes to the breaker. But does both the ground and neutral go to the grounding block?
cincinnati guy is offline   Reply With Quote
Old 01-05-2015, 07:24 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,664
If you have separate bus bars, then the white goes on the neutral bar, and the ground goes to the ground bus.
If they are connected, then you can put them on the same bar, but not under the same screw.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 01-06-2015, 04:21 AM   #3
Rewards Points: 1,832
The neutral wire goes the neutral bar, while the ground wire goes onto the ground bar. If this is a main panel and not a subpanel the ground wire can go to the neutral bar as well. Never place a neutral wire on a ground bar (one that is attached directly to the can and not on plastic supports)
If unsure post a pic of the panel and I can guide you as to where appropriate.
Jump-start is offline   Reply With Quote
Old 01-06-2015, 07:31 PM   #4
Rewards Points: 463
Yes it is the main service panel. I looked at it more, there is only 1 bus. I wired what I wanted just like everything else. Was successful. Yes the ground and neutral were on the same bus but did not share same lug.
The Following User Says Thank You to cincinnati guy For This Useful Post:
jbfan (01-06-2015)
Old 01-07-2015, 07:09 PM   #5
Rewards Points: 455
Don't forget to pull a permit with IBI on that circuit buddy
Cletis is offline   Reply With Quote
240v 40a oven breaker and wiring. mnbv0987 Electrical 20 04-17-2013 05:24 PM
3 way switch trips breaker over night Hazelberg Electrical 5 09-21-2012 09:34 PM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Tripped breaker after wiring a new dimmer, ok to use dimmer after correcting mistake? toobhed Electrical 7 09-20-2011 08:24 AM
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 10:13 PM
