Wiring Lights To Bedrooms - Electrical - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 04:55 PM   #1
Wiring lights to bedrooms
I currently have no lights in my bedrooms, I want to run wires so I can have lights.
I want to make a new circuit, while I'm up there, I was thinking about adding a light to the attic.
Is it possible to run a wire to the attic for the light, then from there run wires to each room?
ibjames is offline   Reply With Quote
Old 09-20-2010, 05:00 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 968
Yes. If you can reach the attic from the panel you can do this.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 09-20-2010, 05:14 PM   #3
ok.. so lets say I put a junction box in the attic, with no light, is that fine also?
Old 09-21-2010, 10:53 AM   #4
jbfan's Avatar
Rewards Points: 968
As long as the box is accessible!
Old 09-21-2010, 10:55 AM   #5
Super Moderator
joed's Avatar
Rewards Points: 23,990
Being a bedroom it will required to AFCI protected.
Old 09-21-2010, 10:55 AM   #6
ok, thanks, I just like to make sure before I do anything, on holmes on holmes, he always frowns if it isn't accessible from within the living space it seems
Old 09-21-2010, 10:58 AM   #7
Just call me Andrew
Rewards Points: 1,032
I would much prefer a junction box in the attic - there is easy access to all rooms from there.
Post if you have questions on how to run your new circuit, and like Joed said, bedroom circuits need AFCI protection.
Andrew
secutanudu is offline   Reply With Quote
Old 09-21-2010, 11:13 AM   #8
I just googled it
Does that look good?
http://www.ehow.com/how_4835951_inst...i-breaker.html
I'm beginning to think I need a wiring diagram
Running wiring at joists for pot lights georgeo Electrical 1 07-21-2010 06:10 AM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
Wiring for new bedrooms Sammy Weld Electrical 15 10-22-2008 03:49 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 12:39 PM
Wiring lights on vaulted ceilings Unregistered Electrical 4 01-31-2008 09:39 PM
