Wiring Issue....I Think - Electrical - DIY Chatroom Home Improvement Forum
Old 05-06-2012, 08:51 PM   #1
mathman32's Avatar
Lightbulb
Wiring issue....I think
Hello,
In our master bathroom, we have a light fixture that holds six bulbs lined up in a row. I turned the lights on and a spark flew out of one side, and all of a sudden, three sockets on the left no longer function. Any ideas?
mathman32 is offline   Reply With Quote
Old 05-06-2012, 08:53 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Sounds like something shorted out and blew a splice apart behind the fixture.
Old 05-06-2012, 08:57 PM   #3
mathman32's Avatar
So if I take it off the wall and tighten everything up, it should work again?
Old 05-06-2012, 08:59 PM   #4
k_buz's Avatar
Probably, the curious part is that if it did short out, why didn't the breaker trip?
The Following User Says Thank You to k_buz For This Useful Post:
mathman32 (05-06-2012)
Old 05-06-2012, 09:02 PM   #5
mathman32's Avatar
Good question. I'll take the thing off the wall and see what's going on behind it.
Old 05-06-2012, 09:05 PM   #6
Rewards Points: 18,990
There's going to be 6 white and 6 black wires all connected together to link the bulbs together that all get connected to the black and white wires from the incoming power wires so it's easy to not have all of them connected nice and tight.
You need to kill the breaker to this light. Right now you have a dead short.
Most of those style lights have to have the bulbs removed in order to get the cover off. Look fo any pinched wires around the cover.
Old 05-06-2012, 09:57 PM   #7
Rewards Points: 6,652
Sometimes it happens. Weakest link always acts like a fuse and will blow before the fuse blows. Works the same as the fusible link on your car's DC voltage system.
Old 05-07-2012, 07:28 AM   #8
Rewards Points: 3,438
You will need to test the fixture for shorts with the lamps removed. While unscrewing the lamps check for the glass bulb being loose from its screw base where small wires inside get twisted togethere which is often the cause of shorts in light fixtures.
Use the ohms or continuity function of a meter. Nearly zero ohms between black and white after all loads are removed indicates a short. For these functions power must be off and at least one of the two places you touch the meter probes to must not be connected to anything other than the test subject (unhook the fixture wires from the cable wires going into the wall).
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 12:17 PM
Issue with thermostat wiring for baseboard heater jschell Electrical 3 01-30-2011 07:30 AM
GFI wiring issue voless Electrical 4 10-20-2010 01:37 AM
House electrical wiring issue. gnidaerd General DIY Discussions 5 06-07-2009 02:42 AM
Century Home Wiring Issue fradam1976 Electrical 14 05-07-2008 01:53 AM
