Wiring House To Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 09:10 AM   #1
Wiring house to garage
Right now the hydro for my garage is separate from my house so i'm paying for 2 delivery charges. I want to run power from my house underground to my garage. My garage has a welder, fridge, freezer etc.
What type/ size of wire do I require to do this. The distance from between the two panels is 80-90 ft. Anything else I should be aware of?
stonehaven is offline   Reply With Quote
Old 05-31-2010, 12:55 PM   #2
Rewards Points: 1,016
Hi - where are you located? This will help others to help you better.
Old 05-31-2010, 12:59 PM   #3
In Ontario, Canada
Old 05-31-2010, 05:14 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 23,990
What is the welder size? What size panel is in the garage now?
Old 06-01-2010, 12:42 PM   #5
Rewards Points: 2,800
A 4-3 with ground direct burial copper cable for up to 75 amps, or a 2-3 w/g for 100 amps.
Or separate wet area rated conductors in buried conduit.
With a 40 amp welder and just a 60 amp subpanel you'l be continually worrying about other things turned on and possibly overloading the feed from the house.
Psst! Many Canadian POCO's have "hydroelectric" in their names as a lot of the power is generated at dams and waterfalls.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 06-01-2010, 09:26 PM   #6
It started out that way in the beginning, now in Ontario its mostly nuclear.
Quebec and BC are hydro electric users!
Old 06-02-2010, 06:55 AM   #7
50A Welder
125A Panel
Old 06-02-2010, 06:19 PM   #8
Master Electrician
k i'll give you the by the book answer....bare with me lol.
125A seems a little excessive i'd downgrade that to 100A...plus double check that your main service is good for it before you start.
the 125A service requires 2 #2 R90XLPE hots and a #6 neutral under the new code. This can be a problem as the lugs need to be sized for this in the panel and personally i think it's just better to size your neutral the same as the hots.
cable depths(appologies for the decimal points but the codes in metric now)
with no mechanical protection (eg pressure treated plank)
23.6 inches in pedestrian areas
35.4 areas in vehicular traffic area's (driveway)
with mechanical protection
17.7 inches in pedestrian areas
29.5 in vehicular areas.
three inches of sand or screened earth above and below the pipe and a cation tape buried roughly halfway down.
Here's where things differ from the U.S alot
you can use a loadcenter here as long as you've got your 125A breaker in the main panel. There needs to be a grounding rod installed at the new building with a minimum #6 grounding conductor wired to the panel. The grounding conductor goes into the new panel, through the lug, and gets TIED INTO THE NEUTRAL BAR along with the neutral from the house.
I know alot of you are going to yell NO but i'm taking this right out of the CEC's newest version.
A quick check with your inspector might be a good idea as well because the distance of 80ft. could go either way depending in the mood their in they may want a larger conductor.
anything else just holler.....i got my new code book in the mail last week and need excuses to use it
andrew79 is offline   Reply With Quote
wiring from existing panel to new garage al99m Electrical 8 07-29-2009 08:42 PM
Wiring project in my garage... Albatraz Electrical 4 05-20-2009 04:18 PM
Critique my wiring plan for my garage tigereye Electrical 10 03-24-2009 09:55 PM
Service line from house to garage.... question Todd-sta Electrical 24 11-10-2008 12:23 PM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 03:56 PM
