Wiring For A Dual Fuel Range - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 03:31 PM   #1
Rewards Points: 12
wiring for a dual fuel range
Home built in 1991. I have 30 amp 3 wire in the breaker box & a 50 amp. What would be best to use on the 220 range, 3 prong or 4 prong? Was told to use a #8 wire.
Any ideas out there? Thanks.
Papa John is offline   Reply With Quote
Old 11-18-2010, 07:37 PM   #2
" Euro " electrician
frenchelectrican's Avatar
The best answer is check the dual fuel stove for more infomation and they will have the ampacity listing on it and that will tell you what size breaker and conductor it need.
Typicaly dual fuel stove will useally required 30 amp some case 40 amp circuit again check the specs to make sure.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Papa John (11-19-2010)
Old 11-19-2010, 10:07 PM   #3
Rewards Points: 12
Wiring
Marc,
I talked to the sales person & was told it was a 50 amp. I don't believe it. I had 2 other people tell me it was 40 amps. My problem now is that I have a 50 amp breaker from an old range but can't locate the other end of the wiring. It's somewhere in the same wall area. Any ideas or tricks to locate the other end?
Thanks for your help.
Old 11-20-2010, 12:27 AM   #4
If you have basement it will useally come up thru the floor or the wall however if you have slab floor it will useally come from the top but few case it will pop up thru the conduit which I have see it from time to time.
But to find it you should not able miss it due the conductor or cable size is pretty big but with the recetptale at the wall it may poke thru the wall but few case I have found a hidden junction box { rare but it did show up }
A tip to find it if you are from basement is take a quick mesurement from knowen poked thru like plumming or a duct work and mesure from there.
Majorty of the homes stud useally are 16 inch on centre but NOT always the case.
And the range recpetale or cable should be pretty much right on the floor level.
Oh yeah one more thing if you find them in hidden the wall take a extra step and get a NCV { Non Contact Voltage tester } and verify to make sure the power is off or look at two pole breaker or cartage fuses }
Merci.
Marc
Old 11-20-2010, 10:58 AM   #5
Rewards Points: 12
Wiring
Marc,
Thanks for the info. I don't have a basement but I can see from the breaker box in the garage that the wiring runs upwards into the attic.
Looks like I'll be doing some crawling around up there to see if I can find that wire.
Thanks again.
Papa John
what is the differnce between a 35/5mfd 440 vac dual run capacitor and a 40/5 440 and does anyone have the wiring diagram. Neece HVAC 6 10-28-2010 05:51 PM
Wiring for ceiling fan/light with dual switch at end mcherno925 Electrical 26 10-22-2010 11:41 AM
Dual Fuel Range Elec Hookup Qman Electrical 2 11-28-2007 08:22 AM
Replacing Stove Top with Range the.vicster Electrical 3 02-23-2006 05:12 PM
Range Wiring merlin Electrical 1 11-19-2005 11:00 PM
