Wiring A Dishwasher - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2010, 09:07 AM   #1
Wiring a dishwasher
I have been told to run a dishwasher off a 15 amp breaker, but with most all the sites i have been too it says not to run a dishwasher off 15 amp to use a 20 amp breaker. Is it ok to use 12-2 wiring or can i run a 14-2 wire. in our current house it is a 15 amp breaker with 14-2 wire going to it and it works fine. The project that im working on right now doesnt have a dishwasher at all, I just want to make sure that one is hooked up the correct way. I also have a free spot in the breaker box so any size amp can be put in. can someone clear this up for me. So far everything in the house that im working on right now appears to be 14-2 even all the plugs in the kitchen, and if it makes any difference this is a modular home.
Thanks,
Brett
brettadam18us is offline   Reply With Quote
Old 03-20-2010, 09:16 AM   #2
Master Electrician
Rewards Points: 5,082
A 15 amp circuit will work for most dishwashers. Consult the installation instructions.
brric is offline   Reply With Quote
Old 03-20-2010, 09:19 AM   #3
Just call me Andrew
Rewards Points: 1,032
If you aren't sure, just use 12-2 wiring. It's not that much more expensive, and you can use either a 15 or 20 amp breaker with it. If you use 14-2, the max breaker you can use is 15A.
Andrew
secutanudu is offline   Reply With Quote
Hard wiring a new dishwasher install. avro1 Electrical 11 02-28-2010 11:43 PM
Wiring gone bad??? Dishwasher issue beginnerDIY Electrical 38 09-06-2009 07:30 AM
Exposed dishwasher wiring secutanudu Electrical 15 04-20-2009 10:44 AM
Wiring a plug to a new dishwasher fxk142 Electrical 2 08-06-2008 02:45 PM
Dishwasher Wiring mcpusc Electrical 1 04-28-2008 08:19 PM
