Wiring For A Commercial Cheese Vat From EU - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2014, 11:42 AM   #1
Wiring for a commercial cheese vat from EU
Hi everyone, I'm purchasing the pictured teak/stainless cheese vat from Holland. It's currently being refurbished and the builder is wondering what kind of electrical I'd like the motor wired for. The vat will go into a small grade A dairy several years down the road. The dairy hasn't been planned/built yet. Any help is greatly appreciated.
Thanks,
Mike
Mikey Donuts is offline   Reply With Quote
Old 02-16-2014, 11:59 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I don't think there is enough information to give you an answer as you don't know what electrical service will be brought to the building. I would assume you would bring 277/480 3 Phase then install transformers for specific applications. Having it wired for 208V 3 Phase would be a pretty safe choice, but it could be cheaper to wire the circuit supplying it if it was wired at 480V. There is just too many unknowns to give you a specific answer.
The Following User Says Thank You to k_buz For This Useful Post:
Mikey Donuts (02-16-2014)
Old 02-16-2014, 12:05 PM   #3
Rewards Points: 3,396
Pretty cool.
Would make a nice bath or hot tub ....
ritelec is offline   Reply With Quote
The Following User Says Thank You to ritelec For This Useful Post:
Old 02-16-2014, 12:26 PM   #4
Thanks for the replies. The builder is thinking 230v single phase for the motor. Would that work?
I'm not concerned with the building wiring right now as that can be figured out later and made to accommodate the equipment.
Old 02-16-2014, 01:13 PM   #5
Idiot Emeritus
Rewards Points: 80
230 single phase would be the most universal voltage, provided it can operate on 208 volts as well. Most 230 volt motors are perfectly fine on 208, but since the actual supply in unknown, it'd be wise to plan for both.
Here's the standard voltages that would present at a dairy.
1) 120/240 single phase. Same as a house.
2) 120/240 3 4 wire ∆. Same as a house, but with the 3rd phase added in.
3) 120/208 3 wye. No 240 here, only 208.
4) 277/480 3 wye. No 240 here, it must be derived from a transformer. The transformer will yield one of the voltages listed above, most likely 120/208.
If the motor will operate on either 208 or 230 single phase, you're covered no matter what voltage the dairy is supplied with.
Rob
P.S. There are a number of advantages to using as 3 motor, but since the supply in not known, single phase is likely the best choice.
micromind is offline   Reply With Quote
The Following User Says Thank You to micromind For This Useful Post:
Old 02-16-2014, 01:17 PM   #6
You should request the electrical requirements of the vat from the seller before you plan a circuit.
davenc is offline   Reply With Quote
The Following User Says Thank You to davenc For This Useful Post:
Old 02-16-2014, 01:35 PM   #7
Thanks very much guys. I'll get with the seller again and see if I can get any more specifics on the motor.
Mike
Old 02-16-2014, 02:18 PM   #8
Super Moderator
joed's Avatar
Rewards Points: 31,618
More importantly you want it wired for 60 Hertz, not the 50 hertz they use in the Europe.
The Following 3 Users Say Thank You to joed For This Useful Post:
micromind (02-16-2014), Mikey Donuts (02-16-2014), mpoulton (02-17-2014)
Old 02-16-2014, 02:27 PM   #9
Not sure. 240v 415v 3 phase. 50 hz.
Might be a different thought to get needed hp of motor. And control schematic.
Let them keep the motor and controls and you rewire when you're ready.
Two cents.
Old 02-16-2014, 10:03 PM   #10
Rewards Points: 808
Holland and most of Europe use 230v to ground at 50HZ. Your best bet is to have a 208/240v volt tolerant, 60 HZ motor and controller installed.
IslandGuy is offline   Reply With Quote
The Following User Says Thank You to IslandGuy For This Useful Post:
Old 02-17-2014, 08:06 AM   #11
Rewards Points: 18,784
If you had of added your location profile and mentioned what county you planned on building this barn in there would have been less confusing, conflicting answers.
Just go to quick links to edit.
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 10:00 AM
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 12:17 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
