Wiring A Ceiling Mounted Exhaust Fan In A Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2010, 09:20 PM   #1
Question
Wiring a ceiling mounted exhaust fan in a bathroom
I am installing a new ceiling mounted exhaust fan in my bathroom, I want to run it so that it comes on with the light, I have a power point (non switch type that I am going to install in the roof cavity, can anyone explain or send me a quick diagram showing where to connect into and which wires go where.
Gibbo is offline   Reply With Quote
Old 09-10-2010, 09:37 PM   #2
Take a black and a white from the light to feed the fan, thats it
macdonald is offline   Reply With Quote
Old 09-11-2010, 07:44 AM   #3
Electrical question on ceiling fans
Is it the same when setting up a power point in the roof for the exhaust fan to plug into, or do I cut into the light circuit prior, running the positive from the light to the positive in the fan and then the negative back to teh light?
Old 09-11-2010, 07:55 AM   #4
If your light is on your ceiling. Remove your light fixture. Bring a 14/2 into the box from the attic and then into your fan. You will marrett the new black with both the black or red wire feeding your light and the fan at other end of wire. You will then marrett the white at the light and the other end of the wire at the fan.
Powerpoint is a computer program.
Feed would be the correct term your looking for. IE My power feeds into the attic
If you do not have a fan already, look for a fan that has low sones (Quieter) You really do get what you pay for.
Old 09-11-2010, 08:00 AM   #5
Just call me Andrew
Rewards Points: 1,032
What do you mean by "power point"? Are you talking about a receptacle/outlet?
You don't wire a bath exhaust fan and plug it in. You direct wire it. If you want it to come on whenever the light is on, You need to run 2-wire (+ ground) from the fan to your light.
Depending on how many wires you have in your switchbox, you could also run the wire from the fan to the switch.
Andrew
secutanudu is offline   Reply With Quote
Old 09-11-2010, 08:18 AM   #6
Licensed electrician
Rewards Points: 3,662
Before you go any farther I would suggest you pick up "Wiring Simplified" and do some reading.
AC wiring does not use the terms positive and negative.
Old 09-11-2010, 08:19 AM   #7
Just call me Andrew
Andrew
Old 09-11-2010, 08:45 AM   #8
Not sure what books are available where the OP is located - Australia
Old 09-11-2010, 12:01 PM   #9
liscenced electrician
Rewards Points: 540
a 12/2 might be needed if thats whats run on that circuit, therefore since im just giving blind advice here. I would just run a 12/2
1. cut the hole for your new fan.
2. dissassemble the light from inside the bathroom to get to the box that is mounted in the cieling/wall. Ceiling would make your life a lot easier.
3. run a 12/2 romex cable from that lights box into your new fan hole. If the box is in the wall, you will need to drill from the attic down into that wall cavity
4. staple your wire to secure it, make it look as neat and professional as you can. don't leave it all twisted. straight lines here
5. disassemble the fan, put an appropriete romex connecter in your fan for the romex and get in the attic and mount your new fan enclosure
6. put the cable into your fans connector, and tighten the connector. Don't over tighten
7. Strip the cables outer insulation/extra paper off the cable in the fan box and the light box. Leave a half inch of sheath inside the boxs
8. assemble the fan
9. wire nut the black to the black on the fan, the white to the white on the fan, and the bare copper wire to either a green wire, bare wire, or put a hook on it and wrap it around a green screw if thats what they give you.
10. wire nut the bare copper wire to the other bare copper wires in the light box, the white to the other whites, and the black to the wire that went to the lights black.
11. put the light back together and mount it and assemble the fan
12. turn on power and see if it works
13. g'day mate
heres the diagram you asked for of how your light is hooked up, it will be one of two ways, with power going to the light first or power going to the switch first. I think this is just going to confuse you, all you really need to know, is you hook the white and black to the white and black on the light
http://img543.imageshack.us/img543/3949/diagram.jpg
jimmy21 is offline   Reply With Quote
Tar bleeding through paint on bathroom ceiling dwoloz Painting 5 08-15-2010 08:10 PM
Anyone decipher this bathroom wiring? schnitz411 Electrical 8 08-08-2010 02:21 PM
Bubbling paint on ceiling caused by damp bathroom floor garv19 General DIY Discussions 4 04-10-2010 07:38 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 09:52 PM
Ceiling fan wiring beezlebub03 Electrical 8 05-05-2008 06:34 AM
