Wiring Ceiling Fan And Light With Separate Switches? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2013, 10:33 AM   #1
Wiring ceiling fan and light with separate switches?
We have 2 separate switches on wall. Each has a black and white wire.
Old ceiling fan and light had 2 (b&w) wires to light portion, and 2 (b&w) wires to fan portion.
New ceiling fan/light only has 3 wires: black, white, and blue (I'm omitting green ground from the discussion). Black wire goes to fan and blue wire goes to light.
Do I tie all the white wires together, and then one switch's black wire to the fan's black wire, and then the other switch's black wire to the light's blue wire?
I'm just not sure about tying all the white wires together, if that is safe.
dukes909 is offline   Reply With Quote
Old 08-07-2013, 10:52 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,812
Are the whites tied together inside the switch box?
If so, no problem.
If not, you would need to check and make sure it is the same circuit.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
dukes909 (08-07-2013)
Old 08-07-2013, 11:05 AM   #3
Yes, they are tied together at the switch box. Both fan and light switches are on the same circuit.
Old 08-07-2013, 08:39 PM   #4
Rewards Points: 150
If tied together at switch box then you're fine
romex1220 is offline   Reply With Quote
Tags
ceiling fan , electrical
