Wiring Cable And Cat5 - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2016, 06:58 PM   #1
Rewards Points: 26
Wiring Cable and Cat5
I'm working on a complete remodel on a bedroom and am wiring right now. I've never wired coax cable or cat5, but I want to start it in the bedroom and eventually into the living room and the second floor bedroom.
My question is, can I run both next to each other? Also, is having my modem mounted next to my electrical panel going to cause interference problems with my internet? Anybody have a good online reference for basics on the two?
I don't have cable TV, just internet, but I want to have it in the wall so the next owner has the option.
Thanks.
Josh
Sent from my XT1093 using Tapatalk
Radcon91 is offline   Reply With Quote
Old 11-27-2016, 07:43 PM   #2
Rewards Points: 18
Re: Wiring Cable and Cat5
From a code standpoint, there's no issue in running the cables together.
However, you can expect to have signal issues in the CAT5 if you run them in parallel with AC power cables. Ideally you would want them to only cross eachother perpendicularly.
I work on industrial controls systems, and we segregate CAT5 and instrumentation wiring from any AC wiring. AC will induce voltage in any nearby conductors, and this can cause interference or signal issues with the CAT5.
Best to separate them if possible.
ZackG is offline   Reply With Quote
Old 11-27-2016, 07:53 PM   #3
Master Electrician
Rewards Points: 5,336
However, you can expect to have signal issues in the CAT5 if you run them in parallel with AC power cables. Ideally you would want them to only cross eachother in parallel.
What does "cross each other in parallel" mean?
brric is online now   Reply With Quote
Old 11-27-2016, 07:54 PM   #4
Rewards Points: 3,234
My question is, can I run both next to each other? Yes. I never had any problems with interference or crossover doing this.
Also, is having my modem mounted next to my electrical panel going to cause interference problems with my internet? Yes, It's possible it may pick up emf interference. I wouldn't recommend it. But again, I never had any problem. Mine is close to my electrical panel, but not next to it.
Anybody have a good online reference for basics on the two? I'm sure there is. Someone will probably site a good link. You can try the famous google search "running cat 5 and coax together", and "modem and electrical panel" , for additional information.
Thanks.
Josh
Good luck in your project josh. Great that you are getting information. Hope you get everything wired and working like you want.
Others will be along with more advice/info..The above info I sited is my opinion only, others may not agree.
jmon is offline   Reply With Quote
Old 11-27-2016, 07:59 PM   #5
Rewards Points: 18
Ha. Damn good question. I meant perpendicularly. Just typed too fast. Fixed my post. Thanks.
Old 11-27-2016, 09:18 PM   #6
Rewards Points: 637
Coaxial cable is shielded, and it should not interfere or get interfered. Note that quality matters: some cables have better shields than others! Usually the thicker is better.
csab_ is offline   Reply With Quote
Old 11-28-2016, 05:21 AM   #7
Rewards Points: 80
Coax and Ethernet won't have issues being together. Like Zack said, keep them away from power as best as possible.
Cheers!
supers05 is offline   Reply With Quote
Old 11-28-2016, 06:55 AM   #8
Rewards Points: 2,972
You wrote " I want to have it in the wall so the next owner has the option."
Since "Cat 5" cable is somewhat "yesterday", the best option which you could provide for the "next owner" (at this stage) is to use Cat 6 cable via a "Patch Panel", of some size or description.
If you do not know what a "Patch Panel" is, I suggest that you "look it up".
Hopefully, a small amount of extra "capital expenditure" (Say, for a "Patch Panel"), could provide a much better "installation".
Perhaps you may consider that which I have written and then, possibly, expand your "installation horizon", by just a little.
FrodoOne is offline   Reply With Quote
Old 11-28-2016, 10:51 AM   #9
Rewards Points: 26
Thanks for the info everyone. I do have a follow-up question about the modem proximity to my electrical panel. Being that "close" is a relative term, what would be considered "too close". My panel is mounted to the far right side of a piece of 4x4 ft plywood. If I mounted my patch panel and modem on the far left side would that be far enough? Or would I be best off finding a different spot entirely?
I've done some more research and pretty much decided on using cat6 as suggested.
Thanks again.
Josh
Old 11-28-2016, 11:40 AM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 18,220
I believe in your original question you were talking about running the coax and CAT together.....no issues doing that.
If you keep the stuff 6" or more away from any AC lines, you will also be fine. The reality is, they could be next to each other and still really wouldn't be an issue. Your AC is 60Hz, the other stuff is MHZ. The only real potential is 60 Hz AC being induced on the shield of coax...but since any good device is going to be transformer coupled, it's not going to be an issue.
If it was me, I'd be running Cat6. It has a slightly heavier gauge of wire and will work better for POE. It also has a slightly higher freq range which makes it a better 'future' choice.
Coax....RG6 You do NOT need quad shield.
Help with CAT5 and phone wiring mbrando1994 Electrical 33 02-17-2016 06:04 AM
Splicing CAT5 Ethernet Cable, Help? Jigglebox Electrical 1 08-07-2015 09:11 PM
Running data cat5 cable in walls fdmillion Electrical 2 01-17-2013 07:15 PM
Running cat5 wire over ventilation / heating ducting ajtool General DIY Discussions 7 06-11-2010 12:45 PM
10 gauge outdoor power line and security camera cable (not coaxial) vahlesm Electrical 4 05-01-2010 11:30 PM
