Wiring In Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2010, 10:40 AM   #1
Weekend Warrior
Wiring in Attic
Will be running 10 circuits perpendicular to the trusses on the floor of an unfinished attic (with pulldown stairs) above an attached garage. The runs will be next to the truss webs near the middle of the space. The middle third of the space has particle board flooring.
From what I can tell, I will need to use guard strips, running boards, or another type of cable protection for the wires where they cross over the trusses. Does anyone have suggestions for what to use?
H2O Engr is offline   Reply With Quote
Old 01-18-2010, 10:58 AM   #2
Rewards Points: 308
If you had less cables I would have suggested drilling holes. Since you have so many cables (10), install running boards and staple the cables to them.
Old 01-18-2010, 01:39 PM   #3
Rewards Points: 150
When you say the install running boards, can this be something like a 1 x 8 or a cut of piece of 1/2'' cdx plywood or is running board something else?
Once the running boards are down you can just use the large staples that you see hold electrical wires to say a vertical running 2 x 4 stud in a wall???
Hope this information helps all and the original post
canyonbc is offline   Reply With Quote
Old 01-18-2010, 03:21 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
simply put: you need to guard the cables so they cannot be stepped on.
what to use? anything that is thicker than the cables and is stable if you stepped on it so it will not break or become dismounted and allow the cables to be damaged.
what you use is less important than simply complying with the required function.
Old 01-18-2010, 07:06 PM   #5
Weekend Warrior
Exactly the kind of answer I was looking for. Thanks!
Wiring Protection for Accessible Attic BillyDIY Electrical 6 11-05-2009 08:44 PM
wiring code w.r.t. NEW folding stairs in garage attic fredsterl Electrical 4 09-25-2009 11:05 PM
Attic wiring question everyman Electrical 4 07-07-2009 09:47 AM
Rules for wiring inside the attic amdspitfire Electrical 4 04-09-2008 08:48 PM
Running New Wiring to Attic PCC Electrical 12 02-08-2008 04:09 PM
