Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 08:18 PM   #1
wiring
I have a detached garage about 50 yrds. from house i ran electric out to it from house using a empty double 60 amp breaker i installed a box in garage and everything is running fine i want to add a welder and it says it needs 54 amps the wire i ran out to garage is i think 3 or 4 gauge i am afraid of tripping the house breaker cause of to much draw could i raise the 60 in house to 80 or so ?
bill50 is offline   Reply With Quote
Old 02-02-2010, 08:25 PM   #2
You need to verify the wire size & the type of wire
But #4 is good for 75-85a depending upon the wire
Old 02-02-2010, 08:27 PM   #3
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
#4 THWN is good for 85 amps and a 90 amp breaker meets the code requirements.
#3 THWN is good for 100 amps.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 02-02-2010, 08:36 PM   #4
its copper strand looks like theres about 9 strands and all together wire is 3/8 and outside with insulation and all is 1/2
Old 02-02-2010, 08:39 PM   #5
You need to verify the wire - it will be marked with a rating...#3...#4 etc
Direct burial ? Conduit ?
Old 02-02-2010, 08:51 PM   #6
cant see numbers on there its buried
Old 02-02-2010, 08:53 PM   #7
Direct bury or conduit ?
You should still see markings on the wire in /near the panels
Old 02-02-2010, 09:59 PM   #8
Rewards Points: 1,016
How much capacity do you have in the main panel? What size is the main panel/breaker?
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
