Wires Crossing Plumbing Pipe - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2009, 02:35 PM   #1
wires crossing plumbing pipe
I'm extending some plumbing pipe for a new kitchen faucet. One of the new pipes (the cold water pipe) will be crossing some electrical wires at a 90 degree angle (the wires go to the disposal, dishwasher, and something else). Is this safe? Is there a barrier or protector needed between the pipe and wires? Do the wires need to be rerouted? Thanks for any help.
sm99 is offline   Reply With Quote
Old 05-26-2009, 03:02 PM   #2
DIYer
Romex shouldn't be hanging loose down there, but there's nothing special that needs to be done about the pipes.
Gigs is offline   Reply With Quote
Old 05-26-2009, 03:11 PM   #3
The wires and pipes are inside the wall, so the wires aren't hanging loose. Thanks for your reply.
Old 05-26-2009, 06:55 PM   #4
Registered User
Termite's Avatar
It is a non-issue. You're good to go!
1/2" pipe fittings don't fit old pipe- PLEASE HELP carjack Plumbing 1 05-21-2009 03:22 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
electric cable crossing (hot water) copper pipe amakarevic Electrical 4 09-17-2008 04:10 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 12:27 AM
Flexible pipe for plumbing bigboyjoel Plumbing 2 06-26-2007 11:43 AM
