Wire Through Ceiling Or Walls? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 12:31 PM   #1
Wire through ceiling or walls?
Hello all, first time posting. I am running two 20 amp circuits using 12/2 and 12/3 NM cable in my mancave, an 8' x 8' part of our carriage house out back.
The question is simple. Is it better to run the wires through the ceiling or the walls?
My main concern: temperature. there will only be a 3 1/2" space in the ceiling when finished, and in summer it gets pretty hot up there. I am studying code and I know according to NEC Table 310.13(A) THHN has a maximum operating temperature of 197 degrees F.
I know the ambient temperature will probably be well over 100 degrees in the ceiling space, not including any loaded temperature of the cables. You can feel the radiant heat with your hand. The walls will certainly be cooler but the ceiling is safer in terms of chances of fastener penetration.
Bundling: up to one 12/3 + two 12/2 cables for about 1 foot in the ceiling and 30" in the wall.
Thanks for your advice.
Sunstar is offline   Reply With Quote
Old 09-12-2011, 02:23 PM   #2
Rewards Points: 6,652
What is this circuit for? If pulling Romex, everything has already been figured in. As for what is better, it depends on the difficulty of the job. As for the ceiling, how do you plan on insulating that, along with the walls?
Old 09-12-2011, 04:55 PM   #3
One 20 amp circuit powers a small fridge, computer and audio gear. Another 20 amp circuit powers two lights, a small ac unit, a small electric space heater and one extra outlet.
The walls and ceiling will be insulated with R-13 nonfiberglass insulation.
Old 09-12-2011, 05:04 PM   #4
You only need 15 amp for the lighting. The fridge, I would put on a separate circuit from the computer and audio gear, plus place either on opposite legs, so you do not induce any noise into the electronic gear. The ac, space heater I would put them on separate 20 amp circuits each, and the extra outlet can come off the fridge circuit. So, you should have 1 15 amp for lighting, 4 20 amps. You can get by on a 60 amp sub-panel if placing the circuits in that space on a sub, if not pulling to the main panel.
framing basement walls with furred ceiling BlueBSH Building & Construction 10 08-05-2011 12:44 PM
Four wire electrical + ceiling fan ja0019 Electrical 14 05-09-2010 10:31 AM
running wire in finished walls edmart2 Electrical 2 03-08-2010 08:38 PM
moulding on tray ceiling with angled walls mastran Carpentry 0 03-03-2010 01:07 PM
Open beam ceiling and running wire... Alan Electrical 2 12-10-2006 09:14 PM
