Wire Size To New Bath Heat/fan/light Combo - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 11:09 PM   #16
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Proby
I don't think you understand what I'm suggesting by using a 15 amp MWBC but the OP has already ran the #12 from the panel ... so Jims suggestion is likely his best bet.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 07-17-2010, 11:18 PM   #17
Electrician
Proby's Avatar
Originally Posted by Stubbie View Post
Proby
I understand what you are saying, but if we are trying to be code compliant here, 2 15A circuits will not fill in for a required 20A circuit.
Proby is offline   Reply With Quote
Old 07-18-2010, 12:39 AM   #18
UAW SKILLED TRADES
Stubbie's Avatar
The issue is are we thinking outside the box and violating the NEC as to following manufacturers instructions which are calling for a 20 amp dedicated circuit to the unit. The other problem is we have fixed space heating which requires a continuous load calculation for the heater. All this considered requires #12 conductors ... and protection according to 240.4D.
So I concur it would not be code compliant to use a 15 amp Multiwire branch circuit.
Stubbie
Size and type of entrance wire for 200A? Beemer533 Electrical 7 03-15-2010 10:54 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Size of Wire & type of wire agman Electrical 6 11-10-2009 08:13 PM
Wire size for Central Air mwtuck HVAC 2 12-01-2006 05:06 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 07:43 PM
