Wire Requirements For 15 Amp 205 Volts - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 06:18 PM   #16
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
Ah my bad, figured it could depend on a per appliance basis. But I'm also used to dealing with computers and servers, lot of them have switching power supplies that will auto adapt to a voltage range like 110-240. I guess it's always a possibility this heater has such function but I doubt it, for a heater.
Old 10-07-2010, 06:34 PM   #17
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
It is based on the manufacturers listing. If there are multiple voltages listed, then you can utilize that. If it lists only one voltage, then that is what you get stuck with.
an device is tested and rated at the listed voltage. Applying any other voltage is not legal.
Old 10-07-2010, 07:59 PM   #18
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Exactly.
Some radiant heaters (baseboard for example) are dual rated. Heaters with blower motors usually not.
I myself assume the OP has one with a blower.
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 18 11-02-2016 03:15 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 02:37 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
