Wire Nuts W/ Holes In Top - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 01:12 PM   #1
Knows everything but that
Rewards Points: 150
Wire nuts w/ holes in top
I picked up some new wire nuts yesterday and when I went to install them, one of the wires ends up sticking out of the top of the wiring nut. What is the point of this and isnt that rather dangerous? Maybe I bought something for a special application but I dont see anything specific on the packaging. Im afraid that when I push the wires and nuts back into the box that the black may end up lying against the metal box. Am I just paranoid?
Shane
JakAHearts is offline   Reply With Quote
Old 06-07-2010, 01:16 PM   #2
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
You bought the wrong wirenuts and you should not use them for live circuit wiring! They are green, right? And they are made for the ground wiring only with the hole in the top being used for a ground wire to go through and attach to the ground terminal on a device.
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 06-07-2010, 01:24 PM   #3
Rewards Points: 150
Well, no, theyre not green. Theyre red but returning them sounds like a good plan. :D
Old 06-07-2010, 03:07 PM   #4
Master Electrician
Rewards Points: 5,082
Those are used for pigtailing. Use the wire nut to connect the conductors together in the j-box. Connect the other end to the switch or recep.
brric is offline   Reply With Quote
Old 06-07-2010, 03:51 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
I've NEVER seen a wire nut with a hole in the top that was not green.
Can you post the info from the package? I am very curious to see what these are.
Old 06-07-2010, 03:58 PM   #6
Master Electrician
http://www.idealindustries.com/produ...ut_pigtail.jsp
Old 06-07-2010, 04:58 PM   #7
Super Moderator
joed's Avatar
Rewards Points: 23,986
No hole in those wire nuts. The pigtail is already attached.
Old 06-07-2010, 04:58 PM   #8
Sparkaholic
Rewards Points: 150
Originally Posted by brric View Post
That is not what the OP is describing
Old 06-07-2010, 05:01 PM   #9
Master Electrician
That's exactly what he is describing.
Old 06-07-2010, 05:06 PM   #10
Brric, you think he is describing Term-a-Nuts?
Old 06-07-2010, 05:13 PM   #11
Master Electrician
Of course he is. He says there is a wire sticking out.
Old 06-07-2010, 05:32 PM   #12
Sparkaholic
Rewards Points: 150
No, read the title of the thread "Wirenuts with holes"
And when he installs them the wire sticks out through the hole
Old 06-07-2010, 05:44 PM   #13
Master Electrician
Give me a break.
Old 06-07-2010, 05:45 PM   #14
Jak, please clear this up!
Old 06-07-2010, 07:59 PM   #15
Rewards Points: 150
Wow, didnt mean to get everyone in a brawl here. Sorry Brric but it looks like youre on the losing end of things here. There is no wire sticking out of the nut until after I am installing it. Looking over my original post, I see how you were confused. Thanks everyone for all your help. Any information is good information! :D
Shane
How do I wire these switches? keano016 Electrical 2 10-07-2009 10:19 AM
Wire Nuts jamiedolan Electrical 36 09-16-2009 11:41 AM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-14-2009 11:17 PM
What is the best way to wire this? RST Electrical 8 08-18-2009 11:29 PM
New Dryer is 3 wire, receptacle is 4 Wire. thelimit Electrical 22 01-15-2009 09:59 AM
