Wire Gauges, Amps And Small Fixtures - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 09:23 AM   #1
Wire Gauges, Amps and Small Fixtures
Hey,
Based on a previous post, I take it that one should NOT use 14 gauge wire even for a small stretch of wire on a 20 amp circuit.
[What I had wanted to do was use 12 gauge wire from the switch to the breaker box and 14 gauge wire from the switch to the fixture (because I have to use a 8 cubic inch fan pancake box, which only seems to fit a 14 gauge wire).]
When I look at the wires of my fixture (a wall sconce) the wires affixed to the sconce seem really thin. They seem to be much thinner than 12 gauge wire. Nothing in the instructions of the sconce indicate a limit to the amp circuit that can power the fixture.
So, my question is: Can I still use a 20 amp circuit to power this fixture even though the wire of the fixture seems to be a thinner gauge?
If so, why is it that I should NOT use a 14 gauge wire from the switch to the fixture? Is it because that is a longer run of wire?
Thanks in advance for your expertise,
Red
RedBear is offline   Reply With Quote
Old 11-06-2010, 10:45 AM   #2
Electrical Contractor
kbsparky's Avatar
Tap conductor rules allow for the smaller leads of a fixture to be connected to a larger circuit conductor without the need to adjust the overcurrent protection values.
The installation of permanent wiring to feed a fixture does not qualify for that exception, however.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
RedBear (11-06-2010)
Electrical wire size question. shawnlee Electrical 11 08-11-2009 06:25 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
Proper Voltage for small Nichrome heating element. Dacr0n Electrical 8 01-19-2009 11:30 AM
Generator as sole power source NGuy Electrical 29 12-20-2008 12:29 AM
GFCI Trips campbellpt Electrical 28 11-21-2008 03:06 PM
