Wire Clearance - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2010, 11:01 AM   #1
Wire clearance
I'm trying to determine whether I can run an existing wire over a new parallam beam. We are installing the beam to support overspaned floor joists below the living room of our 1908 house. Weyerhaeuser's iLevel specifications say that no holes may be drilled in a parallam that has a point load -- this beam will be inspected along with other permitted renovation in our home. There is a 3/4' space above the beam then 3/4" underlayment, 3/4" fir strip flooring, then oak strip flooring over that. This depth exceeds the NEC requirement, but is running a wire here allowed?
Thanks.
housefxr is offline   Reply With Quote
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
