Will This Be Ok? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-20-2010, 04:49 PM   #1
Rewards Points: 356
will this be ok?
I have a 220-240v? 1 h.p. submerssible well pump. I asked my well guy and it is ok to run 10g wire for this up to 630'. The pump is 240' down w/ 10g wire running up to a control box. I need to run 10g wire from control box, about 300' to a temp power pole and run pump for a FEW HRS. I have about 200' of 10g wire, i will then have to hard wire the end onto a plug, plug into a 10g extension cord (or two) and then again cut a piece of 10g wire and hard wire into plug for end of extension cord and hard wire other end to 220 breaker. My question is, could all these connections cause too much of a drop and damage pump?
ugabulldog is offline   Reply With Quote
Old 08-20-2010, 05:18 PM   #2
At 630' you will have a 15v drop @ 10a
At 14a the voltage drop will be 21v
Old 08-20-2010, 05:39 PM   #3
Licensed electrician
Rewards Points: 3,658
For a few hours a portable generator might be easier.
Old 08-20-2010, 05:54 PM   #4
Rewards Points: 648
Ask a neighbour about borrowing a generator.Shouldn't cost more than a few beer for rental.
daveb1 is offline   Reply With Quote
Old 08-20-2010, 11:48 PM   #5
" Euro " electrician
frenchelectrican's Avatar
If you going to run just couple hours it will be easier to just rent or borrow the generator for while if you going to hardwire for perament connection you will need much larger conductors
With that distance you will need 10mm˛ { #8 AWG } copper or 16mm˛ { #6 AWG } Alum to keep the votlage drop to the minuim.
Merci.
Marc
