Why Two Circuits On The Same Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By mpoulton
  • 1 Post By lenaitch
  • 1 Post By Marson
Old 09-24-2018, 09:04 PM   #1
Rewards Points: 926
Why two circuits on the same outlet?
I was doing some demo today, and had to get a dead end outlet out of the way. I was a little confused though, as it was wired with 12-3, with the red going to the top gold screw, the black to the bottom, and the tab in between was broken. Of course, I thought I had killed the circuit and got bit when I touched the red, so there are two breakers.
I know a bit about shared neutrals and tying breakers together etc. but I just don't get the reasoning behind this. (a licensed electrician will be wiring this so it's just to satisfy my curiosity.) This is a family room in a finished basement, not some workshop or something.
Marson is offline   Reply With Quote
Old 09-24-2018, 09:14 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 3,590
Re: Why two circuits on the same outlet?
It provides a separate circuit for each half of the receptacle, so twice as much power is available total. This may have been intended for a specific piece of equipment, like an air conditioner. Current code requires the two breakers to have a handle tie, or the use of a double pole breaker.
CodeMatters likes this.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 09-24-2018, 09:14 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 1,764
Either a 'split receptacle' on a multwire branch circuit or half the receptacle is controlled by a switch. If you know for sure it is connected to two breakers, then it is the former, but unusual in a family room. For that setting, more likely the latter.
Split receptacles with a shared neutral allow breaker current - usually 15a - available at each port of the receptacle.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 09-24-2018, 09:31 PM   #4
CodeMatters's Avatar
Rewards Points: 6,154
While the code at the time may not have required the two breakers to
be connected by a handle tie, or the use of a double pole breaker, it
wouldn't be a bad idea to upgrade it with one of the above.
CodeMatters is online now   Reply With Quote
Old 09-24-2018, 10:00 PM   #5
Rewards Points: 120
The switch that controls the black half may just have been off, not conventional but a lot of residential work is done by underpaid beginners and hacks.........and even ignorant DIYers
First find the switch that turns half of that receptacle off and on (why am I so sure there is one? because it's a common arrangement)
There may not be two circuits at all, do you have a multimeter? set it to read volts and stick each probe in the hot sides of each receptacle, if it reads "1"(digital multimeters) it's at least the same phase, if it reads 220 or thereabouts then it's two phases and definitely on two breakers.
Find the circuit breaker that turns either half off, if both halves are off then' it's the same circuit. When you open the switchbox you might see a black wire coming off the switch and entering a cable with a black and a white and ground wire too, the black wire going to a wire nut that the other wire (feeding) to the switch comes out of.
A trade convention fact for you, when professionals wire things with 12-3 we use the black for line voltage (constant hot) and red for the switched wire (switch leg), you might notice that photocells and occupancy sensors often use this same convention.
Sparkomatic is offline   Reply With Quote
Old 09-24-2018, 10:11 PM   #6
Rewards Points: 120
most likely for a lamp in a family room, more likely the same circuit.
Old 09-25-2018, 06:25 AM   #7
Rewards Points: 926
There are two breakers, not switched. I guess someone thought overbuilding was a good idea.
mpoulton likes this.
GFCI or AFCI outlet: no power VAer Electrical 6 06-30-2018 08:47 PM
switch outlet combination phill1 Electrical 4 11-09-2013 08:57 AM
AFCI and GFCI on same circuit -- 2014 Kitchen Rules Perry401 Electrical 12 10-10-2013 10:09 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
