Why Are Switches Grounded? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 11:09 PM   #1
Rewards Points: 252
Why are switches grounded?
Just curious- if all a light switch does is interupt the hot feed in a circuit? Why do they need to be grounded?
mopowers is offline   Reply With Quote
Old 03-15-2010, 11:42 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
because all metal parts that might become energized must be grounded. If the yoke of the switch becomes energized, if using a plastic box, it would not trip the breaker.
since the plate screws contact that metal yoke, the screws would then be energized.
so, if you touched the screw and anything that is grounded, you get zapped.
Old 03-16-2010, 07:21 AM   #3
Rewards Points: 726
You should explain that to the people that built my house *lol* I went around checking all the switches and outlets for ground... they did a good job on the outlets, but not one switch was grounded... been going around doing that myself.... ugh
BlueBSH is offline   Reply With Quote
Old 03-16-2010, 10:28 AM   #4
None are grounded in my home build 12 years ago either.
From what I understand, NEC (at least previous revisions) didn't require switches to be grounded if they were installed in plastic gang box.
That might have changed, because the notes I got back with my building permit (to finish a basement) had a note about grounding all switches.
HooKooDooKu is offline   Reply With Quote
Old 03-16-2010, 11:09 AM   #5
Keep in mind these products are used *everywhere* in all kinds of different situations.
So in some industrial areas or maybe a home garage there might be a metal cover plate used.
Or some fancy homes might have decorative metal cover plates used.
And then keep in mind all sorts of different people wire these things...
Someone might wire one with a bare hot conductor touching a metal electrical box to which the metal part of the switch and metal cover plate is electrically connected and they have not grounded the metal electrical box.
Or someone may not "squish" the wires in all the way and may use electrical tape rather than a wire nut and a bare hot conductor might touch a metal cover plate as the plate is "forced" down on that wire.
In these situations, a grounded switch would be an added bit of protection.
Here is a sample of the wiring jobs some people do (as found by home inspectors)...
(Warning: If you are drinking something, put it down and swallow before looking at the following pictures... )
http://www.terrylove.com/forums/show...n&daysprune=-1
Billy_Bob is offline   Reply With Quote
Old 03-16-2010, 11:19 AM   #6
I've been upgrading my switches in my house
Wires have a ground, but its grounded to the metal box - wrapped around the wire & under the clamp
As I go around I have added a wire from the grounding screw to the box
I do have quite a few metal face plates in my house
Old 03-16-2010, 12:26 PM   #7
Rewards Points: 518
In Canada switches are not required to be grounded but the boxes are. The switch is screwed into the box which therefore usually grounds it anyway. Plastic boxes are rarely used around here. Food for thought.
n0c7 is offline   Reply With Quote
Old 03-16-2010, 12:33 PM   #8
nap
You talking to me?
nap's Avatar
for the screw into a metal box to be acceptable as a ground, it must be listed as a self grounding device. (in the US) There is a slight difference in the construction of a self grounding device and one not listed as self grounding.
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 02:10 PM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 06:19 PM
Grounded electrode on water pipe TW Lucas Electrical 7 05-12-2008 11:33 AM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
