Why A Dimmer Switch On A Ceiling Fan? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-15-2014, 06:46 PM   #1
r0ckstarr's Avatar
Rewards Points: 82
Why a dimmer switch on a ceiling fan?
This is in my kitchen. The light switch on the left works a ceiling light directly above the switch. About 20ft over, there is a ceiling fan with lights on it.
The light switch on right turns the lights on to the ceiling fan. Only the lights.
The dimmer switch controls the actual fan, not the lights. If you turn the dimmer on just past the "click" the fan turns on and appears to work fine. If you turn the dimmer all of the way up, the fan continues to work, but makes an annoying humming sound similar to what a bad ballast in a florescent light sounds like. Turning the dimmer low or high does not change the speed of the fan.
What is the reason for the dimmer switch? Why was it used instead of a regular switch like the ones that control the lights? How difficult is it to swap out the dimmer for a regular light switch?
r0ckstarr is offline   Reply With Quote
Old 10-15-2014, 08:01 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,970
The dimmer was likely installed to control the fan speed. I can't explain why it doesn't control it.
Old 10-15-2014, 08:03 PM   #3
Master Electrician
Rewards Points: 5,374
Dimmers are not designed to control fan motors. Ceiling fan speed controls are required for ceiling fan motors. The dimmer can be replaced with a regular switch.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
oh'mike (10-16-2014)
Old 10-15-2014, 08:06 PM   #4
Abcanfield's Avatar
Rewards Points: 12
Probably not a dimmer but a fan rheostat. Not hard to swap with a switch or fan speed control.
Sent from my iPhone using diychatroom.com
Abcanfield is offline   Reply With Quote
Old 10-15-2014, 08:11 PM   #5
Abcanfield's Avatar
Rewards Points: 12
Why a dimmer switch on a ceiling fan?-imageuploadedbydiychatroom.com1413421889.712001.jpg
Old 10-16-2014, 03:13 AM   #6
dmxtothemax's Avatar
Rewards Points: 7,852
The dimer that should be controling the fan motor
is either faulty or the wrong type of dimer.
Replace it with a new proper fan speed control.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
r0ckstarr (10-16-2014)
Old 10-16-2014, 06:27 AM   #7
Rewards Points: 1,832
IT depends if its a dimmer or one specifically designed for motors. A regular dimmer wont work, however it can dim the incandescent bulbs.
Do you want the bulbs dimmed? Do you want to control the fan speed?
Jump-start is offline   Reply With Quote
Old 10-16-2014, 06:49 AM   #8
Bob Sanders's Avatar
Rewards Points: 2,536
We have one of those old fan rheostats controlling the fan at our cabin. They look exactly the same as the old rotory dimmers, (however they are not interchangeable).
Our fan works the same way. The rheostat operates and controls the speed of the fan just fine. The side effect however at the lower speeds is an annoying hum sound.
Bob Sanders is offline   Reply With Quote
Old 10-16-2014, 08:26 AM   #9
Rewards Points: 1,252
years ago, the fans could be controlled with a basic dimmer. i did it that way, and it worked great. but now, they make the fans a lot more complicated, probably so they will break more often. and a regular dimmer will not work.
Fix'n it is offline   Reply With Quote
Old 10-16-2014, 11:09 AM   #10
Oso954's Avatar
Rewards Points: 1,864
Getting the hum is real common when using a variable speed control on a modern fan.
Try using a 3 or 4 speed control.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 10-16-2014, 11:13 AM   #11
r0ckstarr's Avatar
Rewards Points: 82
Thanks for the information.
Old 10-16-2014, 11:52 AM   #12
Rewards Points: 12
I would be willing to bet that at one time the dimmer was meant for the light and the wall switch was for the fan. I would change the wires on the fan to make the dimmer control the light and the switch to control the fan and use the pull chain control the fan speed
cdestuck is offline   Reply With Quote
Tags
ceiling fan , dimmer switch
Ceiling fan - Light on dimmer switch, Fan on normal switch renderflux Electrical 3 09-10-2012 01:36 PM
Replacing a Dimmer switch with a standard switch zenox Electrical 4 07-26-2012 08:58 PM
Light Dimmer Switch at at the ceiling thone Electrical 1 05-04-2011 08:00 AM
Changing from dimmer to regular switch..help!!!!!!!!!!!!!!!!!!!!!!! Gomezy3k Electrical 8 10-04-2010 03:26 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
