Where Is Ground On Recessed Can Led Trim Kit - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2014, 11:14 AM   #1
Rewards Points: 32
Where is ground on recessed can led trim kit
I purchase halo h750ricat cans and halo led trim kits. I cannot find a place to mount trim kit grounding screw anywhere in the can. Anyone run into this before?
ivanjay205 is offline   Reply With Quote
Old 11-09-2014, 11:46 AM   #2
Oso954's Avatar
Rewards Points: 1,152
They list 3 different attachment methods. Which one you use depends on the make and model can that you have.
Oso954 is offline   Reply With Quote
Old 11-09-2014, 12:22 PM   #3
Rewards Points: 3,396
I was curious where did you find that cut sheet?
Looks like a regular frame in kit that would have a pigtail to the junction box enclosure.
. http://www.westsidewholesale.com/hal...XmdRoCm5_w_wcB
ritelec is offline   Reply With Quote
Old 11-09-2014, 12:29 PM   #4
Rewards Points: 32
So I saw that with the instructions. Is that slot the space where the clips were? I just screw it in there? There is no threaded space.
Old 11-09-2014, 12:53 PM   #5
Master Electrician
Rewards Points: 5,242
Its an h750ricat remodel can. It hasnothing to do with the jbox egc. The trim has a pigtail to be connected when the trim is installed.
http://www.cooperindustries.com/cont...141507-sss.pdf
brric is offline   Reply With Quote
Old 11-09-2014, 12:59 PM   #6
http://www.homedepot.com/catalog/pdf...44196777ed.pdf
Lol.
Ground to trim???
Old 11-09-2014, 01:07 PM   #7
Thanks for the link. I see the approved trims but don't get where it needs to be grounded. Just seeing a screw in A base.
Letting it go.
Old 11-09-2014, 01:07 PM   #8
Master Electrician
What's so funny?
Old 11-09-2014, 01:08 PM   #9
Oso954's Avatar
It is snipped from the instructions for the Halo LED RL560 module.
You can view or download the full instructions at:
https://www.1000bulbs.com/pdf/halo-r...structions.pdf
You are not grounding a "trim", you are providing a good ground to the LED driver in the module.
The Following User Says Thank You to Oso954 For This Useful Post:
ritelec (11-09-2014)
Old 11-09-2014, 01:12 PM   #10
Originally Posted by brric View Post
What's so funny?
That number brought me to a new work frame in. Also to a old work frame in. Not to any trim. The trims I saw from the link did not show a separate ground that needed connection.
Let it go. Not a bigger.
Old 11-09-2014, 01:14 PM   #11
Originally Posted by Oso954 View Post
Ok.
Old 11-09-2014, 06:55 PM   #12
Rewards Points: 32
So I did screw it to the best place I could find. I have to be honest not nearly as secure as I would like it as nothing is threaded... And nothing to really screw into. But all is working and since no one will touch it hopefully it will maintain good contact
Ground wire from panel to ground rod swbrains Electrical 46 09-03-2014 05:05 AM
Recessed lighting trim interchangability? Badfish740 Electrical 5 11-28-2012 01:39 PM
How to remove trim from recessed lighting? (Yes, I'm a newbie) Babalu Electrical 5 09-30-2011 09:40 PM
Recessed Light Trim not flush - tips? sctazmon Electrical 8 10-11-2010 08:20 AM
Installing recessed light trim helpless handyman Electrical 18 07-30-2009 04:35 PM
