What's The Minimum Gauge Wire Required To Run 9volts 50 Feet? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-29-2010, 03:38 PM   #31
Fox
Rough around the edges...
Fox's Avatar
Will do.
Thanks for the assistance, everyone.
Fox is offline   Reply With Quote
Old 08-02-2010, 01:49 PM   #32
Rewards Points: 156
Originally Posted by Fox View Post
*shakes his head* Unfortunately the wiring diagram will now be very simple, if I can do it at all. It'll be a straight circuit of 14-3 from the box to each smoke detector in succession.
I've a feeling you're asking about the wiring diagram of the smoke detector, and modifying it so that the neutral line from the alarm signal is routed through another wire, rather than shunting it off to the AC line's neutral. While I imagine this is very possible, I'll be using different alarms, and that's a bit more complicated than I plan to get in this upgrade. I like the thought though, considered it myself, if only very briefly.
Proby, aye. I'll add a notice to the OP to summarize the thread.
At this point I'm just going to see if I can run a line alongside a doorway to the stairs going down. I might be able to pull this off after all.
Technically, you don't need 14-3 from the breaker box to the "first" detector. There's no place for the red wire to connect in the breaker box.
You only need 14-3 between the detectors.
Good luck.
moondawg is offline   Reply With Quote
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
Framing an unfinished basement captainobvious Building & Construction 7 10-16-2009 09:53 AM
Using higher gauge wire than required? RyanD Electrical 21 05-16-2009 07:23 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
