What Screws For Plastic Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2010, 06:17 PM   #1
Rewards Points: 726
What screws for plastic box?
I have a few of those blue plastic electric junction boxes that I need to put covers over, but they didn't come with screws... what kind of screws can I fit into these?
BlueBSH is offline   Reply With Quote
Old 03-20-2010, 06:22 PM   #2
Master Electrician
Rewards Points: 5,078
probably 8-32
brric is offline   Reply With Quote
Old 03-20-2010, 06:32 PM   #3
Licensed electrician
Rewards Points: 3,652
Typical coverplate screws are 6-32.
Old 03-20-2010, 08:50 PM   #4
Electrical Contractor
kbsparky's Avatar
If the box is a round type, as commonly used for ceiling lights, then an 8-32 screw would be appropriate.
If the box is rectangular, as used for wiring devices (switch, outlet, etc) then a 6-32 screw is what you will need.
I have successfully used coarse thread #6 drywall type screws in both type of boxes ...
-KB
Old 03-20-2010, 09:06 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
2:
and if they are 4" square boxes, they would use 8-32.
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 08:56 AM
What's the trick to get drywall screws all the way in? cody21 Drywall & Plaster 14 08-09-2009 11:05 PM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 12:26 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
