What More Work To Put In 400amp Instead Of 200amp? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Let it Snow
  • 1 Post By TarheelTerp
  • 1 Post By Wiredindallas
Old 11-03-2019, 05:03 AM   #1
Rewards Points: 110
What more work to put in 400amp instead of 200amp?
Is it just putting in a different breaker? So technically, it shouldn't cost any more than the increased cost of the new breaker?
farmerjohn1324 is online now   Reply With Quote
Old 11-03-2019, 05:44 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,528
Re: What more work to put in 400amp instead of 200amp?
No, you have to rewire it from the source with larger wires. But in reality, 400 amp service utilizes smaller wires and TWO breaker panels. You just can't change a breaker and call it a day.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 11-03-2019, 05:45 AM   #3
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,690
Originally Posted by farmerjohn1324 View Post
What more work is involved to put in 400amp service instead of 200amp?
The second 200A panel and different meter gear.
The deeper Q's are about why you think you need it.
TarheelTerp is online now   Reply With Quote
Old 11-03-2019, 05:47 AM   #4
Rewards Points: 110
3 Hvac systems.
Old 11-03-2019, 08:07 AM   #5
Rewards Points: 730
Notify Power Company
Change Meter Socket to 400 amp -320 amp continuous with dual 4/0 lugs
Add second 200 amp service cable
Add second 200 panel with main breaker
Increase ground wire to #2 copper
Pass inspection
Some areas require a License
mpoulton likes this.
Let it Snow is offline   Reply With Quote
Old 11-03-2019, 08:32 AM   #6
MarginallyQualified
3 Hvac systems.
bzzzzzt! the correct answer is "the load calc indicates... "
CodeMatters likes this.
Old 11-03-2019, 08:45 AM   #7
Rewards Points: 110
3 Hvac systems.
HVAC Energy calcs say 130.
But I think that's for HVAC units only.
Old 11-03-2019, 09:01 AM   #8
Rewards Points: 58
Pass inspection
Don't forget to increase the size of the wires from weatherhead to new meter. This will require a larger conduit as well.
Wiredindallas is online now   Reply With Quote
Old 11-04-2019, 06:16 PM   #9
Rewards Points: 1,462
130 amps in 3 resi sized systems? are they all 100% strip heat?
last i checked biggest single phase systems were 5 ton which are about 33A FLA for 100A. load calc has all 3 with no de-rating?
what needs 15 tons of heating/cooling in a single phase environment?
u3b3rg33k is offline   Reply With Quote
