What Are The Holes On The Back Of A Light Switch? Is That Different Than Screwing? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 10:37 AM   #1
Rewards Points: 184
What are the holes on the back of a light switch? Is that different than screwing?
What are the holes on the back of a light switch for?
Is using those any different than screwing the wires in?
I am replacing a switch that has the wires going into the holes on back now. Do I need to use the holes on the new switch as well? Or can I just hold the wires down with the screws on the new switches?
TIA
abefroman is offline   Reply With Quote
Old 08-01-2010, 10:46 AM   #2
Electrician
Proby's Avatar
Using the holes is typically called "backstabbing", it's a bit easier and faster than wrapping the wire around the screw.
Electrician call these holes "Profit holes" because they are quicker to install and they loosen up over time which gives more work to electrician to fix it.
Wrap around the screw.
Be aware, better quality receptacles (spec grade or above) and GFCI's sometimes have holes on the back, but once you put the wire into this hole you need to tighten down the screw in order to lock the wire in. These holes are fine to use. What you want to avoid are the holes with a spring loaded jaw that you just slide the wire into and it holds it automatically.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-01-2010, 10:47 AM   #3
I=E/R
a7ecorsair's Avatar
TIA
The holes allow faster wiring - but is it better? If you were able to release the old wire from the switch, you can use the holes in the new switch or use the two screws. Your choice.
a7ecorsair is offline   Reply With Quote
Old 08-01-2010, 10:49 AM   #4
Just call me Andrew
Rewards Points: 1,032
Do not use the holes, as Proby stated, they tend to come loose over time. Use the screws.
Andrew
secutanudu is offline   Reply With Quote
Old 08-01-2010, 10:59 AM   #5
Rewards Points: 184
Thanks!
I usually use the screws, then wrap tape around it.
Old 08-01-2010, 11:46 AM   #6
Just call me Andrew
Some (a lot of) newer switches and receptacles have "back-wire" (as opposed to the back-stab) connections. You slide the wires under a little clamp, but tighten the screw to clamp the wire in place. Much easier than wrapping the wire around the screw, and secure - I love them.
Andrew
Old 08-01-2010, 12:56 PM   #7
Rewards Points: 2,800
Using the push in holes is acceptable and meets code but using screws or using holes with screw down clamps inside is better.
Wires held in place directly using a screw need to be wrapped around the screw, not just run up straight against the side of the screw -- unless there are ridges that the wire slides into that keep the wire completely under the head of the screw.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Help installing wall switch light timer Aube TI071 Rachey Electrical 10 12-24-2010 11:02 AM
Light Switch Problem duityourself Electrical 5 07-11-2010 07:42 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Fan resets after light switch is toggled texashomeowner123 Electrical 7 12-21-2008 05:00 PM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
