What To Do With Live Wire In Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2010, 10:54 AM   #1
artlover13060's Avatar
What to do with live wire in ceiling
I am replacing the old suspended ceiling in my basement with a drywall ceiling. When I took down the ceiling tiles I found a live bare wire between the joists. What do I do with it? I know which circuit it's on but don't know where it originates. I don't want another junction box in the ceiling and its not long enough to run inside the walls and make an outlet.
artlover13060 is offline   Reply With Quote
Old 01-19-2010, 11:01 AM   #2
Any live wire must be terminated in an accessible box
Old 01-19-2010, 11:03 AM   #3
Inspector/Instructor
codeone's Avatar
Either find the source and pull it out or terminate it in an accessable j-box. No other options.
codeone is offline   Reply With Quote
Old 01-19-2010, 11:12 AM   #4
I'm thinking of terminating it at a smoke detector. There are currently none on this level. Does this sounds like a good solution?
Old 01-19-2010, 12:35 PM   #5
Licensed electrician
Rewards Points: 3,662
If you were to use that wire to feed a smoke alarm it will not report back to any of the other smokes in the house. The smokes are supposed to be interconnected.
Old 01-19-2010, 01:06 PM   #6
Thumbs up
Make an effort to find where (junction box, above fixture) it originates and "kill" the power. You can then tape it up and stick it in the ceiling. But disconnecting from power source is key! Otherwise do as Scuba Dave advised!!!!
spark plug is offline   Reply With Quote
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 02:37 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 12:52 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
