What Breaker Can Be Used To Replace These? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Oso954
Old 10-17-2019, 08:20 AM   #1
Rewards Points: 40
What breaker can be used to replace these?
So I am having trouble finding the exact models of the breakers pictured below (#15 and #17, and #48). Can other models be used in their replacement? Thanks!
What breaker can be used to replace these?-b212c08e-b4ce-45fc-bf03-da5ae8cbf515_1571314795396.jpg   What breaker can be used to replace these?-90b7515b-36bf-4a2c-9576-e0cf49d2a428_1571314831521.jpg
Scm495 is offline   Reply With Quote
Old 10-17-2019, 08:33 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 202
Re: What breaker can be used to replace these?
Those are full sized GE breakers. Why do you want to replace them? There are tandem breakers that could replace them if your panel is rated for them. There are also GFCI or AFCI breakers that can be used.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 10-17-2019, 10:13 AM   #3
Rewards Points: 884
Look on your panel's door. It should list what breaker type it will take.
You might not find the exact model of breaker that is in your panel as breakers are continuously being upgraded. however, they are typical backward compatible.
You want to look for something like THQL or QL, THQP or QP or similar designations.
But as @rjniles asked, why are you wanting to change them? Do you want to go to GFI or AFCI breakers? or do you need more space and want to go to thinline?
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
Old 10-17-2019, 10:49 AM   #4
Rewards Points: 40
It’s fried
Old 10-17-2019, 11:10 AM   #5
Rewards Points: 750
Originally Posted by Scm495 View Post
It’s fried
If the panel is fried, then I would replace with a Square-D panel and breakers - NOT GE. Out of the 6 panel types readily available today, GE is the lowest quality and highest failure rate. G.E., we bring bad things to life!
BluegrassGuy is offline   Reply With Quote
Old 10-17-2019, 11:35 AM   #6
Oso954's Avatar
Rewards Points: 690
I think those are THHQB breakers. GE bolt on breakers.
You won’t find them in a big box store. An electrical supply house that carries GE should have them in stock.
Or, you can order them from Amazon.
How did you determine that the breakers are fried ?
Mike Milam likes this.
Oso954 is offline   Reply With Quote
