What Box Size Is Required Here? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2010, 09:27 PM   #1
What Box size is required here?
I intend to install a piece of 1 1/4" from an LB through a block wall and then into the back of a box. Then I'll run 3/3 lomex from the side of the box to the panel.
What size box is required?
and,
Can or should I use a PVC box (this in inside my house)?
StarGehzer is offline   Reply With Quote
Old 10-20-2010, 10:29 AM   #2
Rewards Points: 308
Whats 3/3 lomex?
Old 10-20-2010, 10:38 AM   #3
Licensed electrician
Rewards Points: 3,662
IIRC lomex is Canadien NM.
Old 10-20-2010, 09:49 PM   #4
Yup, sorry, I should have been clear.
Too cramped to get the conduit into the panel so I plan on using a NM cable to get in.
Old 10-21-2010, 08:04 AM   #5
Electrician
Rewards Points: 910
I would go with a 6x6, either PVC or metal it doesn't really matter. You will have to check the box of the biggest marrete you find and see if it is rated for 2 #3 wires. If it doesn't fit you can buy splices(the actual name is avoiding me right now). It is a little plastic block with two allen keys on it, you put one wire under each screw and that is your joint.
darren is offline   Reply With Quote
Old 10-21-2010, 08:11 AM   #6
Darren, does Polaris or Insul-tap sound familiar?
Old 10-21-2010, 11:11 AM   #7
Thanks Darren...
Instead of marrettes I was thinking of something like this and a wad of rubber tape. http://www.cornerhardware.com/images/17/17088.jpg
Old 10-21-2010, 11:13 AM   #8
" Euro " electrician
frenchelectrican's Avatar
I know Darren mention 6X6 junction box however I feel that is pretty tight escpally if you used #3 conductor size for myself I will go with 8X8X4 junction box size it will give you little more room to work around.
Yeah they do come in both plastique and metal box verison but with metal box you will have to ground it properly.
Merci.
Marc
Old 10-21-2010, 01:29 PM   #9
While the pic of the split bolt posted by Stargazer would work, they are quite a bit of labor to install correctly and take time. The pre-insulated connectors are very reliable and much easier to install. They are also easier to remove should you need to make a change.
Old 10-22-2010, 11:21 AM   #10
Thanks Guys...
Am I correct that a 6x6x4 is ok by code, but an 8x8x4 box makes my life easier? (I like easy.. thats why my underground conduit is 1 1/2")
I'll look into those insulated conectors. I've never seen ones for larger conductors, only for small wires like phone lines.
Old 10-22-2010, 01:07 PM   #11
The big box stores will not have the pre-insulated in my experience. You need to go to an electrical supply house.
Old 10-22-2010, 09:20 PM   #12
Originally Posted by StarGehzer View Post
Thanks Guys...
The insulated connectors are typically found in electrical supply centre but big box store that kinda a long shot very few will stock this big a size but uninsluated verison yeah I have see it.
Merci.
Marc
What size beam to support loft with 16' between supports paperman Building & Construction 3 10-06-2009 05:40 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
pre-hung door, 32x80 is that door size or total size? RyanD Building & Construction 3 06-28-2009 10:33 PM
what size trowel for 4 1/4 x 4 1/4 tiles? Jim W Building & Construction 5 06-21-2009 09:27 PM
Room size X floor tile size deck hand Flooring 4 04-08-2009 04:42 PM
