Wet Bar Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 11:20 AM   #1
Wet Bar Wiring
Hello
I live in Ontario Canada. I am planning to wire a wet bar in my basement. I plan on running a dedicated line to the bar. I plan on having 2 GFI's on the counter. My questions are:
1. Can I run 14/2 on a 15A breaker?
2. Can I add a receptacle near the floor for a small bar fridge?
3. Can I add 4 recessed lights to this circuit?
Thank you.
Ontario is offline   Reply With Quote
Old 03-16-2010, 11:46 AM   #2
Master Electrician
Rewards Points: 5,082
Originally Posted by Ontario View Post
Hello
Thank you.
Yes you can but I personally would make it at least 20 amps and probably 2 circuits minimum.
brric is offline   Reply With Quote
Old 03-16-2010, 11:48 AM   #3
Just call me Andrew
Rewards Points: 1,032
If the outlets are on 1 circuit only the first one needs to be GFCI. Just feed the second outlet from the Load side of the gfci and they will both be protected.
Andrew
secutanudu is offline   Reply With Quote
Old 03-16-2010, 12:09 PM   #4
I already have 14/2 wire. Is it unsafe or against Ontario code to use 14/2 wire and 15A? Since the counter plugs will get minimal to no use is it ok to run 4 recessed lights from same cicuit?
Old 03-16-2010, 10:19 PM   #5
Just call me Andrew
Have you already run the 14/2 wire? Or do you already own it?
It's not unsafe to use a 15-amp breaker with 14/2 wire, but I don't know any Canadian code. (using 14/2 wire with a 20-amp breaker...that's unsafe). The worst that'll happen is you trip the breaker. If you haven't run the wire yet, I'd do it right and run 12/2 with a 20amp breaker. You did mention you wanted a fridge (albeit a small one) on this circuit too, and lights. That's starting to add up, and you never know what you may want to plug in on the bar. Coffee maker? Espresso machine? super high-powered card shuffler???
Andrew
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
