Well Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2015, 12:16 PM   #1
011010100110111101100101
Rewards Points: 196
Well wiring
I checked the local state codes on this and found no specs for roughing this in.
On a well, I assume you are running 1" schedule 40 PVC up to the well casing (based on completed wells I've seen). What is the rule of thumb on the height of the conduit vs well casing?
Are you using an expansion joint ?
The few I've seen done had the schedule 40 going into a well cap of sorts, and had hose clamps holding it on. Is that normal?
-- Joe
anesthes is offline   Reply With Quote
Old 09-10-2015, 01:14 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
This is the one I see all the time. The conduit is run up into the smaller bulge. The wire is often direct bury and the pipe is just a sleeve where iit comes out of the ground.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 09-10-2015, 04:06 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,940
I would think the conduit should be the all the way to the top of t he casing as a protection for the wiring.
Old 09-10-2015, 04:14 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
The conduit is run to the top of the casing.
Old House Wiring Traycam Electrical 14 01-03-2015 09:31 PM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
