Well Help - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2009, 07:58 PM   #1
300zx's Avatar
Well Help
Today the well wasn't putting out much water,Tank is by the house and Well Casing is out in back yard Bladder tank has correct psi in it put new everything on it ,Then pulled the pump out of the casing and put in a big garbage can full of water from pool and it pumps great (about 2 years old).I have about 10 pounds of water presure. The only thing I can think of is the pipe broke from casing to bladder tank does not buid presure.Any other advise would be great Thank You.
300zx is offline   Reply With Quote
