Welder Extension Cord - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2014, 12:15 PM   #1
Rewards Points: 320
welder extension cord
Bought a 170 amp mig welder. It came with a #12 gauge cord with a nema 6-50P plug end. I ran a new 50 amp two pole breaker and (2) #6 THHN wires and a #10 GND into a 4 11/16" box and installed a raised cover with a nema 6-50r receptacle off of garage 60 amp sub panel. The cord on the welder is only 6.5' long and I would like to make up an extension cord so I can use it outside in the driveway. The instructions say that you can replace the cord and plug with a different set up. It recommends using #10 wire up to 75'. I found a nema 6-50p male plug end but there doesn't seem to be any nema 6-50r type female plug end for mounting on a cord. I only looked at the Depot and Lowes so my next stop is the electrical supply house. I would like to extend it about 25'. What is the best option?
1. Make up my own #10 SOW cord with male and female nema 6-50 ends.
2. Replace the existing cord on the welder with a longer #10 cord with the nema 6-50p male plug end.
teamo is offline   Reply With Quote
Old 08-04-2014, 12:19 PM   #2
First Home N00b
Rewards Points: 202
I would go for the extension cord option. I extended the ground, stinger, and power cord on my MIG welder years ago and quickly switched back. Much more difficult to move/store that way. Easier with shorter cords and an extension when needed. Big thick cables don't transport/store/roll up easily.
95PGTTech is offline   Reply With Quote
Old 08-04-2014, 01:01 PM   #3
Idiot Emeritus
Rewards Points: 80
An Arrow Hart 6709N is a NEMA 6-50 female cord end. It looks like a giant version of a normal 120 volt female cord end.
The male version is a 5710N.
Rob
micromind is offline   Reply With Quote
Old 08-04-2014, 01:08 PM   #4
Rewards Points: 320
Good point about the cord storage I'll make up an extension cord.
Thanks for the model #'s Rob
Jim
Old 08-04-2014, 01:09 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 90
Use a 4" square metal box with a raised cover and a 6-50 R recessed receptacle. Use 10-3 SO(J) cord not cable for the extension cord.
My electrical answers are based on 2014 NEC, you may have local amendments.
extension cord wiring streetneons Electrical 3 04-08-2014 10:39 PM
Extension Cord Nightmare garrettc134 Electrical 15 09-25-2012 03:53 PM
Extension cord for generator pkucan Electrical 13 07-05-2012 05:07 PM
I can't find 16 gauge heavy duty extension cord! darsunt Electrical 21 08-04-2009 08:50 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
