Weak Doorbell - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2009, 07:31 PM   #1
Rewards Points: 160
Weak Doorbell
Bought a place, no ringer on the wall (just wires hanging out of the wall).
Purchased a cheap ringer, got it wired up and it works pretty well except it seems pretty quiet.
Says on the ringer that it requires 16VAC and 10VA. I tested the transformer on the breaker panel and it is only putting out 14.8V. I couldn't find anything on the transformer indicating if it's a 16V or.... ?
Any ideas? Transformer not putting out enough juice? Would that even affect the volume?
Thanks in advance
burnt03 is offline   Reply With Quote
Old 10-06-2009, 07:53 PM   #2
Thumbs up
Thanks in advance
14.8v. shouldn't make the bell put out weak sound. Either you have a loose connection on the (original) wires. Or the arm (hammer) on the bell could have moved away a fraction of an inch!No mater what! Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 10-06-2009, 08:18 PM   #3
Thanks in advance
14.8v with no load on it probably means it is a 10v 'former.
If it's 14.8v while trying to ring the bell then I don't understand why the bell doesn't work.
Old 10-06-2009, 08:30 PM   #4
Thumbs up
With all due respect. To me, if my voltmeter reads 14.8 volts, then it's 14.8 volts. If we went on in life that way, that would mean if my VM reads 240v. I should presume that I only have 175v. Yes, we know about voltage drop and load. But a simple bell isn't such a heavy appliance that a drop of less than Two Volts should give a poor quality ring (IMHO). (No matter what)Don't Drink and Drive, Ever!!!
Old 10-06-2009, 08:42 PM   #5
Rewards Points: 160
The bell does work, it just seems pretty quiet compared to other doorbells I've heard. It's possible that's just due to the fact that it's the cheapest one I could find
The connections are all good (at the ringer and the button anyways) and the hammer moves like a piston to hit the "bell", so it's in line.
Maybe I'll try a new transformer from Home Depot one of these days, looks like they're only about 10 bucks.
Thanks for the tips guys
Old 10-06-2009, 08:52 PM   #6
Cheap 'formers could read 20% higher with no load due to poor regulation due to high internal impedance.
You only get the rated voltage when it's under the rated load.
A 16v bell should ring at 14.8v.
The 240vac supply has only dozens of milliohms of internal impedance so you won't see such a voltage change under load.
Same with car batteries. Low internal impedance.
Old 10-07-2009, 09:38 PM   #7
Rewards Points: 160
Changed out the transformer and that did the trick, ringing strong with two tones now. Turns out the old one was a 10V after all (good call yoyizit), the spec plate was on the back side and I couldn't see it
Thanks again!
Old 10-08-2009, 11:46 AM   #8
Thanks again!
14.8v/10v = lousy regulation, but bell 'formers are short-circuit-proof so maybe regulation is one thing they give up in return for safety. Possibly they act more like current sources than voltage sources.
These 'formers might be a subcategory of Saturable Reactors but I haven't been able to confirm this.
All's well that ends well.
Old 10-08-2009, 11:52 AM   #9
Rewards Points: 3,026
Whether it is lousy transformer regulation or the bell unit requiring so much power to ring the bell that you need to select a higher voltage tap on the transformer -- you can burn out the little light in illuminated doorbell buttons if the no-load voltage from the transformer is too high.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Doorbell Diode hindelicato Electrical 15 10-30-2010 10:52 PM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 05:49 PM
how to replace, or maybe swap, this odd doorbell setup joeyboy General DIY Discussions 7 12-16-2007 12:53 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-21-2007 11:08 PM
Tried replacing doorbell....now it doesn't work. ConstantChange Electrical 9 11-18-2007 10:12 PM
