Waterproof Boxes In Brick Veneer? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2015, 04:56 PM   #1
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,566
My friend used regular metal device boxes in his brick veneer and they passed inspection on his new house build. I'm building a new house as well.
I'm curious as to what you guys use and why would a non waterproof box be OK? Or is it OK? I have a copy of our electrical code but it's a jumbled up mess as far as I can see. Hard to locate specific things.
We must use GFCI's or protect with a CFCI breaker of course.
A weather proof cover on the receptacles also.
ESA does the inspections here. Of course my inspector never answers the phone and his message says don't leave a message, ha.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 11-17-2015, 04:59 PM   #2
Licensed electrician
Rewards Points: 3,740
I would use a metal masonry box. This is what they are made for.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
123pugsy (11-17-2015), mm11 (11-18-2015)
Old 11-17-2015, 05:09 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,888
The only reference I could find in the code relating to wet location receptacles is that they must have a wet location cover. I could not find any reference to wet rated boxes.
Old 11-17-2015, 05:15 PM   #4
123pugsy's Avatar
Thanks.
I've never seen a box specifically for masonry.
Up here in Canada, we don't have a ton of products that are available to you all.
Old 11-17-2015, 05:16 PM   #5
123pugsy's Avatar
Thanks.
That's what I believe we have here as my neighbor had no issues with his.
Old 11-17-2015, 06:12 PM   #6
Master Electrician
Rewards Points: 5,252
Use the 3.5" deep boxes. Far easier for installing GFCI's.
brric is offline   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
123pugsy (11-17-2015), oh'mike (11-17-2015)
Old 11-17-2015, 07:46 PM   #7
The advantage of the box brick linked to is that it is the same height as a brick and the screws are inside the box instead of buried in mortar.
Brick veneer over scratch or brown coat? pman6 Concrete, Stone & Masonry 4 01-10-2013 09:14 AM
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 08:09 PM
another brick veneer problem question rdk4609 Building & Construction 6 06-12-2009 09:46 AM
Anchors & Brick Veneer rjordan392 Building & Construction 9 06-04-2009 04:58 AM
Removing a brick veneer Bayou Woman Building & Construction 6 06-02-2009 05:21 PM
