Water Pump - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2010, 11:41 AM   #1
water pump
i have a water pump that pull 9 amps per leg(it has 2 legs).how much power does this pump use per hour?
greg7 is offline   Reply With Quote
Old 11-12-2010, 12:18 PM   #2
Rewards Points: 2,800
What is the voltage?
Is the 9 amps the continuous draw or the startup draw? Did you actually measure it with an ammeter?
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 11-12-2010, 12:56 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,986
240 volts @ 9 amps = 2160 watts
120 volts @ 9 amps = 1080 watts
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
pool pump fill then dumps water nanderson360 Plumbing 2 10-14-2010 10:58 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 08:01 AM
