Washroom Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 08:20 AM   #1
Washroom light fixture
Our washroom light fixture has two bulbs one of which intermittently turns off and on again every few minutes. The fixture was replaced but the problem persists. The other bulb stays on consistently.
Has anyone had a similar problem before? Could anyone please give me a suggestion on what to look for?
Thank you.
Anoop
anoopsb is offline   Reply With Quote
Old 11-20-2010, 10:56 AM   #2
Rewards Points: 2,800
A loose connection somewhere. Possibly inside the light bulb in which case you cannot repair it.\
With the power off check the inside of the socket go see that the tab at the bottom sticks up a little to be sure it puts some spring pressure on the bottom contact of the bulb.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Bathroom Light Fixture with no junction box? shadowman Electrical 2 07-13-2010 06:54 AM
Light Fixture wiring help jdpitt05 Electrical 7 07-12-2010 01:09 PM
outdoor light fixture kills everything on circuit kramwens Electrical 10 10-10-2009 03:50 PM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 09:26 PM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 12:49 PM
