Washer On Its Own 120v Line? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2010, 01:50 PM   #1
Washer on its own 120v line?
I'm looking at buying a new washer (upgrading from a combo unit that runs off a single 240v line) and the manual indicates that it wants its own 120v line with nothing else on it.
Is there any good reason for this? I figure it might need a lot of cranking amps to get started, but it sure would be a pain if I had to run a new 120v line all the way from the breaker box, vs just adding another outlet off a nearby line.
SecretAsianMan is offline   Reply With Quote
Old 01-22-2010, 01:58 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
It's up to you, but if the instructions say it then you should do it. This does not always hold true, but unless you have a dedicated "laundry" circuit already, it IS a good idea.
Old 01-22-2010, 02:13 PM   #3
What do the specs say for the washer ?
How many amps does it pull ?
Some of the new ones do pull a lot - especially if it has the steam option
Old 01-22-2010, 02:53 PM   #4
Inspector/Instructor
codeone's Avatar
If it was being inspected and the mfg instructions were asked for , and thats what they said in the instructions, it would be required!
codeone is offline   Reply With Quote
Old 01-25-2010, 01:15 AM   #5
The instructions say it is "recommended". It doesn't have a steam function, so I don't picture it drawing a whole lot of amps except maybe when the motor's starting up.
Does anyone know if the NEC says anything about it?
Old 01-25-2010, 05:19 AM   #6
An old Tradesmen
Rewards Points: 2,904
Well, you make it sound like the panel box is far a way.
I guess it depends how often you want to have to reset the breaker to let the washer finish washing and rinsing your clothes.
As long as its not your wife doing the laundry. You won't get beat up about it too much.
Old 01-25-2010, 06:23 AM   #7
Will the 240 volt line be used for anything after you disconnect the existing combo unit??
SULTINI is offline   Reply With Quote
Old 01-25-2010, 07:58 PM   #8
Yeah, the 240v line is still needed for the dryer.
Ugh.. Samsung doesn't seem to advertise the amount of load for their washers. If it's only, say, 800W, then I don't think it'll be a problem to run off this one other line. I suppose that would technically violate code though.
Old 01-25-2010, 07:59 PM   #9
An old Tradesmen
Does it have a listing of the motor's horse power?
Old 01-25-2010, 08:05 PM   #10
Aha.. 1/2 HP. Which I think is about 380Watts.
I guess I'm good to go. Thanks!
Old 01-25-2010, 08:09 PM   #11
An old Tradesmen
More like 500 watts. But still not a high amp draw.
May dim lights if they are on same circuit. ½HP motors draw a lot of amps to start.
Old 01-25-2010, 08:35 PM   #12
Thumbs up
It would depend on what the balance of the load is on that branch circuit. (If, as the OP says that it's a major hassle to pull a new line from the breaker). Obviously, a new, dedicated line would be best, probably prolonging the life of the washer.
spark plug is offline   Reply With Quote
Old 01-25-2010, 09:09 PM   #13
Master Electrician
richgriffith's Avatar
1/2 HP Electric motor more like 373 Watts = 3.1 Amps at 120v
richgriffith is offline   Reply With Quote
Old 01-25-2010, 09:19 PM   #14
Question
But if it has a hard start, due to inadequate current flow (or excessive Voltage drop) it'll cause a strain on the motor and might lead to premature failure???!
Old 01-25-2010, 10:16 PM   #15
An old Tradesmen
Yes it can. Along with damaging the control board, from spikes.
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 05:29 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 10:40 PM
