Want To Replace 120 VAC 600 Watt Dimmer...what Works Best??? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2009, 09:06 AM   #1
Want to replace 120 VAC 600 Watt Dimmer...what works best???
Hello everyone, I have a Push-On/Push-Off Rotary Dimmer that is 120 VAC 600 Watts, that controls my chandelier in the dining room, and it is right by a regular 15A. 120v AC only light switch that controls the deck light outside. I would like to replace the dimmer switch with a regular switch like the 15A 120V AC only one right next to it. Is this safe/ok, or do I need to replace it with something else? Thanks for the help!
Noah
noahd33 is offline   Reply With Quote
Old 10-10-2009, 09:46 AM   #2
Code05's Avatar
Rewards Points: 1,104
Yes you can replace it with a regular snap switch, or if you want they make a dimmer with a snap switch and slide. I will see if I can find a picture.
http://www.onestopbuy.com/leviton/TGI06-1LA-5540.asp
Code05 is offline   Reply With Quote
Old 10-10-2009, 09:52 AM   #3
Thanks, I know exactly what type of switch you are talking about. I'm making my way to the hardware store in a few and will check out the different options. Thanks again.
Noah
Old 10-10-2009, 09:54 AM   #4
General Contractor
HWConstruction's Avatar
As Code05 said. Go for it.
HWConstruction is offline   Reply With Quote
Old 10-10-2009, 01:26 PM   #5
Rewards Points: 1,016
I have these and find them annoying to use. We inadvertantly bump the dimmer slide down when turning off the switch. Next we come into the room we have to move the little dimmer slide up again. Not a huge deal, but annoying...
Old 10-10-2009, 01:31 PM   #6
I just went with a regular switch and it works perfect. I have several dimmer switches in the house, but this one was not working well with the cfl bulbs I had in the light, plus we never really used the dimmer anyway. Thanks again guys.
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
How to avoid audible buzz with dimmer switch wkend3 Electrical 4 08-27-2008 09:44 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 10:57 PM
Installing Dimmer for fireplace blower MountainMan HVAC 4 07-02-2008 11:09 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
