Wall Timer Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 05:07 PM   #1
Jdf
Wall timer wiring
Does it matter which switch is used for the timer installation? I believe we have a 3 way circuit. There are two switches that control 4 outside garage light fixtures. We tried a 3 way Intermatic Timer last year but it did not work. Would still like to figure this out.
Any help would be appreciated.
Jdf is offline   Reply With Quote
Old 06-29-2010, 08:53 PM   #2
Do all four lights go on and off together?
Post a link to the general- and install- instructions on this timer.
Old 07-16-2010, 07:49 PM   #3
Jdf
Wall timer wiring
Hi, I too am wiring a in-wall timer to control my outside garage lights. I have read previous posts, but no luck. I believe I have a 3 way set up. There are two switches that control the outside garage lights. The switches each have 4 wires, red,black,white and copper. The timer is a Woods and the instructions are not clear. The timer has 4 wires, red, black, white, green. It does not indicate whether it is single pole or 3 way. I have tried the obvious, red to red, black to black, white to white and green to copper. No luck. Any help would be greatly appreciated.
Old 07-16-2010, 09:40 PM   #4
dSilanskas's Avatar
You have a single pole timer you need a 3 way timer
dSilanskas is offline   Reply With Quote
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 02:55 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Wiring for a wall mount flat screen Badfish740 Electrical 4 01-13-2010 08:21 PM
